Turn Signal Malfunction
Old Sep 30, 2007 | 09:30 AM
Lynnie's Avatar
Default Turn Signal Malfunction
2000 Monte SS recently developed problems with turn signal intermittant malfunction. Dealership couldn't find a problem...it worked for them...go figure...wasn't more than five minutes on the way home and signal quit for me while changing lanes. No rhyme reason or warning. Anyone experience this? Got a fix?
Old Sep 30, 2007 | 11:14 AM
couch's Avatar
Default RE: Turn Signal Malfunction
maybe try replacing the fuse? i'd go back to the GM dealer and tell them it's an intermittent problem. see if they'll pony up the dough for a fuse.
Old Sep 30, 2007 | 12:53 PM
Mrrench's Avatar
Most likely its a flasher issue
Old Nov 24, 2007 | 07:37 PM
Chevy II's Avatar
I have the exact same problem with my 2000 and it could work for a month or two and then twice in one week it would malfunction. Anyways, my fix for this would be (temporary fix) to hit the 4 way flashers for a second and then the signal lights would work again. Right nowmy problemhasn't happened for about a month.
Old Nov 25, 2007 | 06:35 AM
Mrrench's Avatar
replace the flasher unit, you will be fine after that
Old Dec 2, 2007 | 02:17 PM
joesumrall's Avatar
Where online can I find the Hazard/flasher switch for my 02 monte ss? I am having the same problem and from what Ive learned the flasher and hazard switch are built into one. I am trying to find someone that has a decent price that I can order from.
trey0503
Apr 27, 2018 11:39 AM
sasor4755
Aug 10, 2013 09:51 AM
djizzle
Jan 19, 2007 01:05 PM
Nortybignort
Jul 25, 2006 10:35 PM
Lee55
Jun 9, 2006 09:20 AM
