Trunk popup
Old Nov 26, 2014 | 09:13 AM
avendo's Avatar
Default Trunk popup
Does anyones trunk pop up open when you click remote...or does it just unlatch?
Old Nov 26, 2014 | 10:08 AM
03SSLE's Avatar
The trunk should unlatch (but not pop open). If it does it is usually caused by the incorrect (too long) struts being installed when they are replaced.
Old Nov 26, 2014 | 10:12 AM
Mine does pop open...
But then again I have the tension/spring rod set on the highest setting..
That way I don't finger print it up at shows etc when getting thing like my cooler chair/scooter etc out of the trunk.
Just 1 less thing to wipe down.
Old Nov 26, 2014 | 10:27 AM
03SSLE's Avatar
If the trunk pops open you will eventually bend the trunk lid around the hinge area. As far as fingerprints, lift the trunk from the bottom (where it meets the rear bumper cover) and you won't get fingerprints on it.
Old Nov 26, 2014 | 04:52 PM
Actually Mike:
I initially raised it (Tension rod) to aide in opening the trunk with the older style spoiler I had on it.(t was pretty bulky) Even still with the new spoiler it still works quite efficiently.. It doesn't pop wide open but it does open enough that it wont spring the hinges...
At least not in the last 14 yrs I have owned it...
mr. roboto
Jul 30, 2015 06:57 AM
96chevyridinheavy
Mar 23, 2013 10:21 PM
96chevyridinheavy
Mar 17, 2011 07:53 PM
big green dog
Oct 20, 2005 04:25 AM
montejass
May 25, 2005 05:37 AM
