Intake Build: throttle body
Old Dec 5, 2022 | 04:50 PM
Masonlw's Avatar
Default throttle body
is there any way to get a bigger throttle body or an adapter to get a different one I would just get an ss but this is my dead grandmas car. if there isn’t i’ll just engine swap tbh
2004 3.4 liter Ls
Old Dec 5, 2022 | 10:12 PM
This is a pretty wild topic. SO if you cannot get a bigger throttle body, you will engine swap it. I guess it comes down to "what are you trying to accomplish".
The 3400 is more popular in the N-Body/Grand Am crowd, but yes, there are bigger throttle body options.
Or you can half shaft your throttle body. I did this on my 3400 Grand Am years ago. Here is the right up:
https://montecarloforum.com/forum/fw...hafting-56966/
Here is another thread you might find value in:
https://montecarloforum.com/forum/fw...p-power-46071/
Old Dec 5, 2022 | 11:07 PM
Masonlw's Avatar
I thought these looked kinda close to where I could just cut this off but now that I look at it the hole might be really small compared to the 80mm
Old Dec 5, 2022 | 11:08 PM
Masonlw's Avatar
do you have a link to the ones I can get
Masonlw's Avatar
Old Dec 5, 2022 | 11:16 PM
Masonlw's Avatar
if not i’ll just clean up my current one and save up
Old Dec 6, 2022 | 03:22 PM
LX5 TB swap kit (65mm):
https://www.wot-tech.com/lx5-throttle-body-package.html
Keep in mind that you'll likely either need to open the inlet port on the UIM or swap to a 3500 intake setup (which has its own complications) at the same time to avoid creating a step.
If engine swapping is on the table, I'd absolutely go for that instead. Youll get much better bang for the buck out of even a stock L67 swap - plus much easier modding going forward.
A good point of reference is the LX9 engine (early 3500 - pre vvt) as they are very similar to the 3400 you have. They also had a 65mm TB like you're considering upgrading to, but also have more displacement, better flowing heads, a better LIM, and supposedly much better UIM - and still only make 200 +/- crank hp. As you can imagine, just upgrading to one of those improvements isn't going to have a major impact on hp - likely only single digits at the crank.
Red Monte Carlo
Jan 11, 2015 09:23 PM
Jparks
Apr 4, 2013 08:06 AM
irulesoha
May 17, 2010 03:14 PM
Nova1585
Mar 4, 2009 08:54 PM
rcohen
Dec 10, 2006 08:43 PM
