Security on message center
I had that happen to me when I had an old remote starter system. Whenever I remote started the car and then drove off, that message would pop on and only stay on for that trip. If you have a remote starter, that may be the issue.
I have been battling this problem for a while now and its driving me insane... First I thought I was to reprogrammed my key for the security light to go out, then I even disconnected the amp from the factory radio (draining my battery..How I don't know), even change keys and still it does not work. My car cranks when it wants too...smh! I thought getting another key key would be best but its still acting up. Now my only dreading option is buying the ignition cylinder to replace it. I have came across something that was a ?. Called the dealer and they told me that my car does not require a programmed key?! Anyone have gone through the security light with a NOT programmed key?
Most likely some of these wires are going bad and not sending the right charges. Some dealerships will change the ignition system and the wires all at one swing.
If you are comfortable taking it all apart yourself, you might find some discoloring or bad wires that you can probably sand paper and reconnect.
Thanks for the reply Chi but do you have any instructions on how to do? I know I don't wanna attempt to start fixing it and end up with more of a problem from just being "hoping I correct the problem" easy fix....smh! I know my cylinders inside is damaged due to 2yrs ago a tow truck driver hit the head of the key with a flash light so I can turn my key instead of getting towed home. Which the key wouldn't turn and security light came on that night as well, which I was I was stuck So now the original key has problem turning inside the ignition but the dummy key TURNS FREELY ((scratchin my head)). Where is the BCM and PCM? an I repair them myself? Do you know if it has been done by someone?
So Technically I can get an oe key cut and it should work just fine. I had gotten two chip keys from my job and that didn't work (thinking I had to reprogram my vehicle). So, since there is no chip in the oe key, then the dummy key should crank the car just as well as the oe key...Right? Or Wrong?
deadlifter
Feb 17, 2007 07:26 AM
