7th Gen ('06-'07): Rpm jump
Old Apr 22, 2019 | 08:06 PM
Cpetty's Avatar
Default Rpm jump
Noticed whenever car is in drive at idle rpms are a little static jump from around a good 200-400 rpms only when stoped. Idle is a tad bit rough. I assume it’s the nature of the beast or it’s from my 3in exhaust but not sure. I have cleaned my MAF and throttle body to see if there is any difference but no luck. Anyone know of any other possibilities?
Old Apr 23, 2019 | 08:58 PM
I'm assuming you mean its jumping 200-400 rpm beyond stock idle as there's no way its idling at 200?
If that's the case, it's not the nature of the beast - a 400 rpm jump is like 50% of the total commanded idle speed. Something is broken unless you installed a monster cam and just happened to forget to tune it.
I'd grab a scan tool and look at what the sensors are telling you. As with most of these types of threads, its hard to give any accurate advice with just the symptom and no data.
randall729
Feb 17, 2014 01:48 PM
cmww24
Mar 4, 2012 09:46 PM
jwjones
Jan 26, 2012 09:28 PM
itsjustme
Oct 20, 2010 02:37 PM
Brinksta
Jul 16, 2008 06:49 PM
