Opinion Needed: idle problem
Old Feb 16, 2014 | 03:48 PM
randall729's Avatar
Default idle problem
Car won't idle. Will stay running if 1000 rpm or more. At a stoplight has to be shifted in neutral and rev at 1000 rpm. Is there a vacuum hose in particular to check?
Old Feb 16, 2014 | 07:27 PM
Randall:
Welcome to the forum..
Pls feel free to post pics when you can and fill out your profile... (it helps when we know where your from)climate counts.
Join in the conversation in the Members Daily Blog!
Thanks for Joining the MCF Family.
Heres a quick way to check for a vacuum leak:
Take a spray bottle with water set it to mist...
While its idleing.... Spray the vacuum lines ..when you hear the motor start stuttering (miss fireing) you have found the leak.
If you cant find it using spray mists of water...
use a can of ether... and re spray around the vacuum lines when you hear the rpms raise..you know what vac lines to check...
What year and what motor is in your Monte Carlo?
That would also help with answering what lines and or where there maybe a vac leak...
It may also be an issue with IAC (Idle air control)
Which you can remove from the vehicle..give it a through cleaning and replace it and see if that doesn't cure the idleing issue.
Old Feb 17, 2014 | 01:44 PM
randall729's Avatar
I am a new member. Did my profile info.
Old Feb 17, 2014 | 01:48 PM
Randall:
I see that now daaaaaa on my part....lol
97MONTEZ34
Apr 23, 2012 12:28 PM
infine0n
Nov 14, 2009 03:38 PM
Enemyofreali7y
Mar 23, 2008 11:43 PM
vita
Oct 31, 2007 09:52 AM
instantlunch
Sep 30, 2007 12:12 PM
