Removing Back Seat
Old Nov 6, 2009 | 04:25 PM
Default Removing Back Seat
Does anyone know how to remove the whole back seat or an easy way to run wires to the trunk? or is the a way to lift the seat part of the bench to run under that? thanks
Old Nov 6, 2009 | 04:55 PM
RocknSS04's Avatar
Grab hold and lift. When you put it back in, remove the rubbers from the prongs and put them in 1st, then push the seat down, or it won't go back in easily.
To remove the back, there's 3 bolts at the bottom, and a couple on the top?
Old Nov 6, 2009 | 11:38 PM
04MonteLS's Avatar
The easiest way to do it would be to remove the bottom of the seat and then feed the wires under the backrest and into the trunk.
Old Nov 7, 2009 | 09:10 AM
mrl390's Avatar
My seat bottom came out with two bolts up front. I dont know if the 6th gens are the same. I believe someone wrote a how to on removing a 6th gen rear seat. It was a good one IIRC.
Old Nov 7, 2009 | 01:18 PM
i only saw removing the rear deck
Old Nov 7, 2009 | 03:48 PM
jarheadbobandmax's Avatar
Photobucket
Default You rock nsso4
GRAB HOLD.........AND lift.
Amazing you hadn't tried that Trew! ......Hey Trew opening a cooler.... reach down grab pull up..........Let us know if you need help with the soda/beer can!
Old Nov 7, 2009 | 03:55 PM
gothkid's Avatar
like MRL90 said our back seat was pretty simple. All i did was ran the wire threw the right side of the seat and into the trunk. Lol i can show u sometime of u want lol
Old Nov 7, 2009 | 08:15 PM
ill try it out haha, anyone got a cb in their car? im putting one in tonight =p
blackbeauty89
Dec 6, 2012 09:57 PM
jasonsmith
Nov 16, 2011 07:07 PM
BenTheFox150
Jul 26, 2011 12:32 PM
red04montels
Nov 6, 2009 03:27 PM
fastback4
Dec 21, 2008 06:39 PM
