Rear Window Defroster Help
My defroster hasnt worked since i bought this car. Its starting to get cold here at 5am. Every day i go to work my windows are fogged up. I looked at the tabs and using a test light, had no power to any of them(Yes Defroster switch was on). So i took the panel off to follow the wires and found this box. What is it? and could it be the problem?
There is power to the white wire when the car is on. My guess is the green would be the ground. The 2 black wires attach to the window and i have no clue what the wire to the left is.
Any help troubleshooting would be greatly appreciated.
Smitty 911-The Module you shown is the Radio Antenna Module.
The bottom coax cable is antenna connection from the radio.
The green and white wires on the bottom are the antenna module connector. green is 12 v supply from ckt brkr and relay-this is what supplys the pwr for the defogger.. white is for the antenna-ignore for trouble shooting the defogger.
the top blk wire to the lower window grid is for the defogger connection
the top blk wire to the upper window grid is the antenna connection
make note the antenna and defogger grid are in series.
Hope this helps
Hope this helps
i have a 2007 monte carlo and the defogger isnt working either checked the grid and it is ok the light in the switch comes on and i can hear the relay click but im not getting any power to the grid any clue as to where i should look for the problem thanks
jeffsmonte
Nov 21, 2022 07:34 AM
MJClemm
Oct 9, 2022 09:13 AM
TrapShooter8
Jun 3, 2007 08:31 PM
