Another Rear Window Defroster Problem
Old Nov 27, 2010 | 02:02 PM
bsinyukon's Avatar
Default Another Rear Window Defroster Problem
I've read a few of the posts about rear window defroster problems and I'm needing some help with my '06 Monte.
What I've done so far:
with the leads unhooked, I have continuity and good resistance from window tab to window tab. I have good volts from lead to lead. I have continuity from the driver's side tab to ground.
If I hook up the leads to the tabs, I get no volts.
Is my window grid shot? Is there something else I should check?
Thanks for any tips/leads you can give.
Brian
jeffsmonte
Nov 21, 2022 07:34 AM
MJClemm
Oct 9, 2022 09:13 AM
smitty911
Dec 1, 2010 10:38 AM
TrapShooter8
Jun 3, 2007 08:31 PM
01pacecar
Apr 29, 2006 12:38 PM
