Rear fuel rail connection
Old Aug 25, 2012 | 12:27 PM
01 Monte SS's Avatar
Glad to see you got it fixed! I forgot to put a new o-ring after installing my new fuel rails and was not happy to see it spraying out before I even had the chance to start it. I was going to recommend a small pic to get them out, wasn't very fun as I recall. Mine broke as well upon removal.
Either way it's a good feeling to not have anymore fuel leak
Old Apr 19, 2021 | 12:10 AM
BlackFall's Avatar
Default Fuel
Quick Add On..
When Replacing the Fitting and Line Secition with an O.D. style Coupler.. using a Pencil Sharpener to Bevel the edges of the line and a little WD40.. makes it a 5 minute job..
The return line O ring I belive is Dia 3/32 ,I.D.- 3/8, O.D. 9/16 though I believe there are two.
I will add sizes on the Pressure and Return Line if I remember them.
The easiest path is to change the O- Rings... If the Coupler and or Line needs to be changed then look at Available Kits...
Either path is very easy so Dont Stress ... Take your time Bathe ! In That Sense of Accomplishment !
woodr004
Aug 30, 2014 07:09 AM
LittleE
Apr 3, 2013 11:09 PM
apguy
May 24, 2012 01:46 PM
Shandley
Dec 12, 2011 03:29 PM
augi
Jan 25, 2011 10:03 AM
