Rear carpet wet on right side
So lately my carpet will get wet for some random reason. Its not too bad but its been bugging me lately so i figured id post on here ans see if anyone can help me.
It only gets wet behind the passenger seat. The fronts are completely dry and the left side in the rear is completely dry. It hasn't rained hard here in like 2 weeks so I don't think I have a water leak. The only thing I can think of its coming from the A/C. I checked the plug like 2 weeks ago and there was nothing clogging it all. (Well at least I think I checked it. Couldn't tell which one was the drain plug, but I think I checked the right one).
Anyone know what causes this? And why would it only get wet in the rear passenger part?
The back is a strange spot. Perhaps check window and sun roof seals...?
If you were to say the front, I woulda suggested this:
https://montecarloforum.com/forum/si...lem-fix-26663/
I don't think there are any major fluid lines running around the back seats in our cars, with the exception of gas lines, but they are generally close to the frame and you would probably see it on the ground as opposed to on the carpet.
Did you check for a hole in the floor pan? if you hit a puddle of water it will throw up in to the hole and cause the water spot. This actually happened in my dads 87 monte when he had one
Does your car have a sunroof? the condensation from the morning dew may be leaking in causing the wet spot to appear or from the window seal like Jason mentioned in the above post
stupid as it is, but any chance you have a can of anything under the front seat?
And I dont think I have anything under the seat. Will check just to be sure
Ill check the window seals again to double check.
Thank you for the help
blackmonte781
Sep 14, 2011 08:46 PM
