6th Gen ('00-'05): Radiator Fan Override
Old Jul 11, 2015 | 10:51 PM
jraney's Avatar
Default Radiator Fan Override
Does anyone make a radiator fan override switch kit? I had one on my 96 Z28 from SLP
Old Jul 12, 2015 | 03:02 PM
Yes there is such an item, I had a manual fan override switch on my Monte a few years back. I actually still have it if your looking to buy one. It is by Caspers.
Here is a link on ZZP's site of a different brand, but essentially the same. Be careful if you leave the switch on, it will drain your battery, happened to me a few times.
Easy Performance - Hi-Lo Fan Switch #EP-HLFS
Old Jul 12, 2015 | 09:33 PM
jraney's Avatar
Thanks Zippy.
Old Jul 13, 2015 | 08:20 PM
jraney's Avatar
I'd be interested in that set up you have.
Old Jul 14, 2015 | 12:18 AM
I'm going to have to dig it out. It did work 100% when I took it off. Ended up having the pcm adjust the fan turn on points.
Will get back with you in a couple days or so...
Old Jul 14, 2015 | 06:31 AM
jraney's Avatar
Ok sounds good to me
gmartinez93
May 11, 2015 10:45 PM
NYGiantsfan
Aug 15, 2013 07:43 PM
jhbasse
Jan 15, 2013 06:39 PM
MurderCoupe
15
Jun 20, 2012 09:38 AM
wildchild00
Jan 22, 2007 05:37 PM
