Radiator Fan
Old Jan 16, 2007 | 09:59 PM
wildchild00's Avatar
Default Radiator Fan
I have a 2001 Monte Carlo SS and the Radiator Fan runs from the time I turn the vehicle on untila few minutes after I shut the engine off. The Water Temp Gauge is also not working. I have changed the Temperature Sensor and that did not cure it. Any ideas on what would be casuing this problem? Thanks in advance for the help!
Old Jan 16, 2007 | 10:29 PM
01BlkSS's Avatar
Default RE: Radiator Fan
You replaced the coolant sensor, correct? Did you replace the thermostat also? If not, then it's your thermostat. I had the same problem exact problem. I replaced the thermostat and the coolant sensor at the same time. Not sure which one fixed it, but I'm guessing you replacing the thermostat will fix it. Quick and simple fix. Remember to put the gasket on the lip of the thermostat, someone didn't do that and the thermostat housing started to leak. [8D]
Old Jan 22, 2007 | 05:37 PM
golfstud2k4's Avatar
It is the thermostat! I had the exact same problem and the tech II kept reading engine coolant sensor. I replaced the one in the fron right part of the engine (under the thermostat) and that didn't fix the problem, but when i replaced the thermostat I also flushed my system and put new hoses on and then the problem was cured. In the mean time, open up the drivers door when the car is off, then turn the key to aux power and back to the off position and it will turn the fans off so your battery wont die!
gmartinez93
May 11, 2015 10:45 PM
NYGiantsfan
Aug 15, 2013 07:43 PM
jhbasse
Jan 15, 2013 06:39 PM
Sliver
Jun 8, 2010 10:21 PM
01SSMonte
Feb 27, 2010 01:33 AM
