Radiator Fan Override
Does anyone make a radiator fan override switch kit? I had one on my 96 Z28 from SLP
Yes there is such an item, I had a manual fan override switch on my Monte a few years back. I actually still have it if your looking to buy one. It is by Caspers.
Here is a link on ZZP's site of a different brand, but essentially the same. Be careful if you leave the switch on, it will drain your battery, happened to me a few times. Easy Performance - Hi-Lo Fan Switch #EP-HLFS |
Thanks Zippy.
Originally Posted by ZIPPY02
(Post 667699)
Originally Posted by jraney
(Post 667840)
I'd be interested in that set up you have.
Will get back with you in a couple days or so... |
(Post 667855)
I'm going to have to dig it out. It did work 100% when I took it off. Ended up having the pcm adjust the fan turn on points.
