oldest car with 3.8 supercharged
Old Nov 24, 2008 | 04:46 PM
v8_Killa's Avatar
Default oldest car with 3.8 supercharged
so in my quest to do the cheepest top swap for a blower i figure i can get one off of a junked w-body but i don't know what all cars they came in andwhich one is the oldest?
Old Nov 24, 2008 | 04:50 PM
Cowboy6622's Avatar
Default RE: oldest car with 3.8 supercharged
heres a link from Wikipedia, just scroll down to the L67...
http://en.wikipedia.org/wiki/GM_3800_engine#L67
Old Nov 24, 2008 | 09:02 PM
2000_BLACK_SS's Avatar
i would say a 97 GTP would be your best bet but it will most likely have a lot of miles on the engine
Old Nov 24, 2008 | 10:01 PM
kweef's Avatar
y not go to a junkyard and find a newer blower on a newer car instead of tryin to put on an old pos
Old Nov 25, 2008 | 07:56 AM
Cowboy6622's Avatar
if he can find a low mile engine in an older car though.....
Old Nov 25, 2008 | 05:46 PM
kweef's Avatar
superchargers arent corrosion proof tho
Old Nov 27, 2008 | 01:18 PM
v8_Killa's Avatar
so what will in need to do it from a l67 and what about the pcm can i drive it with the l36 pcm and just baby it till i get a l67 one or will i do a good deal of damage?
Old Nov 27, 2008 | 03:14 PM
Cowboy6622's Avatar
i'd think you'd do a good deal of damage using hte other pcm... heck it might not even crank, i don't know. the timing, the valve settings for opening/closing, will all be different i'm sure. plus it's not tuned to take in that much air. i'd think you're asking for trouble.
keep in mind you can keep the same heads, but you need new fuel rails, new fuel lines,etc... (i think)but if you don't go all the way with the top end swap and do the heads too, you'll need a custom tune...
Old Nov 27, 2008 | 05:59 PM
kweef's Avatar
id have to agree with duane on this one...knock would become a huge problem and gradually destroy ur pistons. bumpin will know more, pm him or wait for his to c the thread
Old Nov 28, 2008 | 10:47 AM
rj's Avatar
rj
Well here are some plans I was thinking up a few months back.
If you can locate a decent donor car with the supercharger un the hood. (didn't the Pontiacs get the same engine/trans that the supercharged Montes got?)
I personally would want one with the fewest miles possible.
Pull the entire drive train from the donor car, then do the same with my car. (I'm talking the '03 Pace car here)
The swap should be a bolt in deal.
But besides the PCM, won't you need the ECM (if they came with one) to make the supercharger work correctly in your non-supercharged car.
Plus the other parts Duane mentioned such as the fule line.
One thing here............
I'd measure the diameter of the fuel lines just to make sure.
But you will need the fuel pump from the superchargeddonor car cause that is definately differentthen your's is.
Reasons I haven't gone any farther with these plans.
1. Money.
2. You get in to the "What-If's" with the Pace car.
Well what if it does become a true collector's car?
What if you damage the vaule of it by changing it.
And so on.
Denarius23
Sep 17, 2014 02:18 AM
rj
Oct 24, 2013 10:27 AM
Dam20735
Dec 1, 2012 08:35 AM
blackbeauty89
Nov 22, 2011 06:21 AM
zero32700
May 8, 2010 11:42 AM
