New Rims recommendation
I am thinking about buying new rims for my 2007 LS does any one have any recommendations? What is your favorite brand and why? Anything I should watch out for like offset? Is the LS any different than SS as far as space for offset or larger rim size? I have 16" and don't plan to change that as I just bought a new set of tires. What do you all think about junk yard rims? Thanks for any info
If it were up to me, I'd upgrade to a 17" or 18" wheel & tire combo, since (IMHO) 16" just looks a bit too small on 6th & 7th-gen Montes. The slightly bigger wheels provide more "face" that goes well with the seemingly bigger body style, and look more up-to-date.
But I see you want to stick to 16" since you've already got the tires. Well, you've still got some choices; it depends on the style you'd like.
You could always go to tirerack.com, look for wheels, and specify 16s for your 2007 LS and see what they have to choose from; that'd be a good starting point.
@Sidestreet I just looked at a parked new chevy cruze with 16 inch rims they looked so small obviously the width of the tire was less but had me thinking about what you recommended about upgrading to 17 or 18". If I did I am wondering if that will throw off the speedo or anything else? would I need to change the profile of the tire to compensate for overall height?
Yes, when upgrading to larger wheels (like 17 or 18"), the tire profile needs to decrease in order to stay close to the car's original stock tire size. Otherwise, yes, the speedometer will be inaccurate, and other odd things might happen.
Let me check my tire-shopping notes... ok, a 225/60R-16 tire setup like a typical 5th- or 6th-gen Monte Carlo has measures 676.4 mm tall (26.6 inches).
If you can find a 245/45R-18 tire, that measures 677.7 mm -- practically an exact match to the stock 16" overall height.
The 2004-2005 Monte Carlo SS (supercharged) had 235/55R-17 tires (690.3 mm tall), and the 2006-2007 SS had 235/50R-18 tires (692.2 mm tall). So they were a little taller, about 27 inches tall; I don't know if that's within some margin of error size-wise (and I'm not some tire pro). As for wheels, I think some later-model 17" and 18" Chevy wheels (like off the 2008-2013 Impala) would fit fine on the MC and look decent. Of course, so would the 17" or 18" MC SS wheels.
Oh, and stock wheel offset is 40 mm (give or take 5 mm).
Puppet Master
Sep 29, 2007 12:26 PM
