Need Help with the Deuce Please
Old Mar 23, 2014 | 07:50 AM
  #31
03SSLE's Avatar
The stuck key/shifter are signs of a dead battery, but since the battery was just charged it makes me think a fuse has blown. Sometimes a fuse can look good, but may be open near the prongs where it is difficult to detect. Even if the fuse(s) in a circuit look good you should check them with a continuity tester to verify their condition.
Old Mar 23, 2014 | 10:34 AM
  #32
My Moneys on a fuseable linkl!
Between the battery and the starter!
Whos willing to bet me?
Old Mar 23, 2014 | 11:44 AM
  #33
Stumpmi I put a volt meter on the battery she is reading out 13 volts and some change
I am assuming that means it is ok? No I do not have another battery that will fit. I did also try to jump her off the Malibu no dice.
I am done stressing over it any more. I got so irritable yesterday with everyone at home. I am just going to let my Mechanic buddy at Frankie Dee's in Holt MI work his magic on her. going to try and enjoy the rest of the week-end.
Also David thanks for devoting so much time to me in trying to help !
Old Mar 23, 2014 | 11:55 AM
  #34
Your Quite Welcome my Friend!
Its my understanding....
There is a fuseable link that connects the power to the rest of the vehicle.
As I understand it... The power cable goes to a power pole/block before it goes to the starter and from there..theres also a fuseable link that goes from the power pole/block to the ignition.. That's the one I believe is causing you all this Greif!
Tadd:
Anytime you need anything..Feel free to count on me to help you out!
Old Mar 23, 2014 | 06:20 PM
  #35
03SSLE's Avatar
There's a fusible link on the solenoid, but it is for the alternator. You could have fried the coil in the starter relay, but you would have had to go through 2 fuses in order to do that...
Old Mar 23, 2014 | 07:25 PM
  #36
Mike that's the very same diagram I looked at yesterday!
Old Mar 23, 2014 | 08:05 PM
  #37
Will let you all know what the shop finds becoming a bit of a mystery story
LegaBone
Aug 20, 2012 03:30 PM
Tadcaster
26
Apr 9, 2012 11:12 PM
Tadcaster
Feb 5, 2012 11:45 PM
blackmonte781
Oct 3, 2011 01:38 PM
rmase182ls
Feb 28, 2011 03:57 PM
