mustang t5 87 monte carlo
Old Oct 25, 2011 | 03:45 AM
nighthawk626's Avatar
Default mustang t5 87 monte carlo
guys is it possible and what all do i need if it is possible?
Old Oct 25, 2011 | 10:45 AM
what are you asking?
assuming an engine swap?
If so probably the harnesses, tranny, engine mounts etc.
Old Oct 25, 2011 | 11:53 AM
Budsjlm's Avatar
T5 is a 5sp trans,
do some digging find out weather the input shaft has different splines, length ect, if i am not mystaken it should bolt up to a chevy bel housing no problem but that may be another thing you need to check
also tail shaft spline as you may have to make a hybrid yoke for the drive shaft if it's differnet
Old Oct 25, 2011 | 06:16 PM
mrl390's Avatar
I would assume the bell housings would be different. If I may ask, why a T5? They have a pretty bad rap for being weak/unreliable.
Old Oct 25, 2011 | 09:13 PM
monte07's Avatar
i had one in my mustang only lasted for a hour after i did all the power upgrades as in wont handel abuse either if the engine is stock either. my sugestions is getting one from tremic of a trans shop that builds trans to suit high out put engins. me personally i went with a t56 from tremic yes it is a six speed manuel. i think the t5 is the minimum ok trans for the basic set up
Old Oct 25, 2011 | 09:14 PM
monte07's Avatar
i ment tremic or one from a trans shop
Old Oct 25, 2011 | 11:09 PM
thanks guy. after more searching i found a z28 6 speed tranny for $1000. doesnt have clutch pedal tho. what do you guys think? i just got into manual and i love it. i dont wanna miss out on an opportunity
Old Oct 26, 2011 | 02:16 AM
Budsjlm's Avatar
With the t56 you will want to find one out of a LT car not a Ls car if you plan to bolt it behind a small block,
You can do a ls t56 but it will end up costing more becuase you'll need to get adapters to make it work
The lt T56 will bolt right into place the only thing I am not a fan of is the way the clutch is
The one your looking at doesn't have a clutch pedal? Go to the junkyard
Old Oct 26, 2011 | 05:22 PM
cool thanks man. i love the turbo 400 but u really cant go wrong with stick shift.
Cowboy6622
Apr 21, 2011 06:49 PM
06MCLTZ
Oct 6, 2008 02:27 PM
00pacecar
Jul 6, 2006 02:18 AM
mcarloss04
Nov 16, 2005 10:01 PM
