lowering question
Old Jun 12, 2013 | 02:11 PM
Dale_Jr_123's Avatar
Default lowering question
I wanna lower my 04 dale jr a so that it is closer to ground without changing the rims and tires basically the body lowered so less room in tire well and it sits closer to ground. How much should that cost me about? ANYONE HAVE PICS OF A LOWERED ONE AND WHAT IT LOOKS LIKE? What should i tell my speed shop exactly what i wanna do in "their language?"
Old Jun 12, 2013 | 04:41 PM
turbo monte's Avatar
here are some, many other vendors sell them as well this is the first place i thought of is all. there is many lowered cars here im sure someone will post up a pic, i am not lowered so cant help there. and yes wheels and tires will work with these springs.
Performance Lowering Springs
Old Jun 12, 2013 | 05:12 PM
Here's a few pics of my 06 lowered on Bilstein HD Series struts and Canuck Motorsports lowering springs. I've lowered both of my Montes (both my 03 SS and 06 SS) and each time went with new struts and strut mounts at the time I lowered them (stock parts were at 80k miles both times). Depending on the age of your current struts, I would recommend replacing those as well, as installing a lowering spring on an older worn strut is not a good idea. Obviously, if you install new struts I'd recommend going with new strut mounts as well. That said, cost can add up quickly if you are replacing struts and mounts. A set of lowering springs themselves usually run for less than $200; Canuck Motorsports for the Monte Carlo go for $150 for the set of four. Their springs for the 00-05 drop the front 1.7" and the rear 1.5", so basically the same as mine. Total cost for parts can vary significantly depending on what you're replacing and exactly what brand/parts you choose to go with. Any other questions, feel free to ask.
One Dark SS
Jun 20, 2010 07:47 PM
fastback4
Jun 10, 2007 09:50 PM
04MonteLS
Aug 13, 2005 03:09 AM
kevin187
Nov 14, 2004 12:41 AM
kevin187
