Leaky Cowl
Old Sep 25, 2009 | 10:17 AM
swanny09's Avatar
Default Leaky Cowl
Anyone else had a problem with a leaky cowl? My floorboards have been wet everytime it rains and I thought it was something to do with the floorboards. But today I noticed a small stream of water coming from under the dash. So I tore the cowl apart and found that there is a hole (from the factory) right next to the cabin air filter. I think if I weld a small piece of metal in there to cover up the hole, that will solve the problem. What do you think?
Old Sep 25, 2009 | 10:20 AM
Budsjlm's Avatar
is it round?...if so i's say just go to a parts stor or dealer and get a plug ...that way no painting need or exposed metal to rust
Old Sep 25, 2009 | 10:25 AM
swanny09's Avatar
Its an oval. I'd say its 3" x 1.5"
Old Sep 25, 2009 | 10:35 AM
A lot of times when people replace the cabin filter, they incorrectly put the weatherstripping back on and that causes the water to run in
Old Sep 25, 2009 | 10:43 AM
swanny09's Avatar
Well I also noticed that there was a little water in the corner of the filter closest to the oval hole. Theres a little bit of weatherstripping on the cowl that that kind of shriveled up that I will have to replace. I might just end up finding a thick piece of plastic and exopy that over the hole if I cant find a rubber plug
Old Sep 25, 2009 | 12:15 PM
drewskie043's Avatar
cut out a thin piece of metal (ie aluminum since it's easy to work with) or plastic oversized to your hole, run a bead of silicone around it and cover up the hole.
Old Sep 25, 2009 | 12:31 PM
MarkIV396's Avatar
Default factory pop-out plug?
That sounds like a factory plug should go in there. I know that my
Impalas (from the '60's) have those in cowl & firewall...
You might ask a dealer parts guy - or check out a salvage yard ....
Overdose666
Mar 11, 2012 07:52 PM
06MCLTZ
Oct 27, 2007 02:06 PM
full_monte
Sep 22, 2007 09:11 PM
rgast3
Jul 25, 2007 04:27 PM
79Monte
Feb 2, 2007 11:10 PM
