leaky(?) spark plugs....
Old Jul 23, 2007 | 07:53 PM
rgast3's Avatar
Default leaky(?) spark plugs....
Ok. I own a 1995 Z34 w/ 200k on the engine. I recently noticed that when I start my car a fluid is comming out of my front spark plugs. I think it is oil but im not sure...I am sure that fluid is not supposed to be coming out of spark plugs.Anyone have any Idea of whats going on?
Old Jul 23, 2007 | 07:57 PM
RocknSS04's Avatar
Default RE: leaky(?) spark plugs....
Sounds like a loose plug to me. They can and will loosen if not properly installed. Everything has to be CLEAN! It's easy to tighten it down on dirt.
http://www.cardomain.com/ride/2319272
Old Jul 24, 2007 | 08:24 AM
wiz kidd's Avatar
not a good thing, i would take a look into it if there's oil coming out of where the plugs are
Old Jul 24, 2007 | 09:55 AM
rgast3's Avatar
im pretty sure its oil....so is that usually bad o-ring/gasket? does anyone know where I can find instructions online on how to fix oil leaks in a 3.4 dohc?
Old Jul 25, 2007 | 04:27 PM
04 Intimidator's Avatar
Make sure it is coming from the plug and not the head gasket leaking into the plug. I know some of the Gen 5 Montes had that issue.
If not the head gasket, then I would just buy a new plug for $2 are replace it.
01blackmonte
Mar 20, 2007 10:06 AM
golfstud2k4
Jan 6, 2007 04:24 AM
2000_BLACK_SS
16
Sep 26, 2006 04:36 PM
2000_BLACK_SS
Sep 23, 2006 10:11 PM
bk4256
Mar 28, 2005 06:37 PM
