Intermittent Cooling Fan Noise
Hello,
I've a 2000 Chevy Monte Carlo, 3.4 L engine, 110K miles. The cooling fan is making a intermittent loud noise for some reason or another. Have any of you had this problem out of your Monte Carlo? If so, how did you resolve it? Can the motors be purchased separately or will I have to buy the entire cooling fan assembly? Also, could this be a bearing problem? The fan doesn't appear to be rubbing against anything. The fan is running after the engine is turn off although the engine wasn't real hot.................driven under 15 miles and fan came on and stayed on after turning off engine but finally stopped running. Thanks for any assistance provided!
cmw239
Sep 12, 2007 06:52 PM
