Installing H.I.D. kit on 2004 Monte Carlo...question
Old Dec 15, 2008 | 10:17 PM
stangkilr's Avatar
Default Installing H.I.D. kit on 2004 Monte Carlo...question
They will not come on...? They were in my 02 Camaro and a neighbor kid wanted me to put them in his 04 Monte Carlo to see if he liked them. Well I got them all hooked up but they wont come on. Any special method to install these on a monte? Its the same bulbs as my Camaro has, work fine in my car. Any help would be great! Thanks guys.
Old Dec 15, 2008 | 10:23 PM
2000_BLACK_SS's Avatar
Default RE: Installing H.I.D. kit on 2004 Monte Carlo...question
Did you put them in the high beam or low beam light. also check all the fuses because when i put mine in they blew the fuses as soon as i turned the car on the first time.
Old Dec 15, 2008 | 10:52 PM
stangkilr's Avatar
Put them in the low beam spot. Which fuses do I need to check? I checked the drl fuse under the hood and even tried a 20 amp fuse but that did not fix the problem. I know its got something to do with the drl, it has to.
Old Dec 16, 2008 | 12:50 AM
nemesis's Avatar
2009 Monte Of The Year
might be the ballast went out. did you have a a seperate hid wire harness and when unlock and lock the doors does the low beam flash? you don't want the headlight to flash cause it will shorten out the ballast.
Old Dec 16, 2008 | 11:06 AM
stangkilr's Avatar
The kit works just fine on my Camaro.....
Old Dec 16, 2008 | 09:34 PM
inssanity21's Avatar
when i did my fogs they didnt but something was on backwards. i think it was one of the plugs into or outta the ballast.
hope they work
Old Dec 16, 2008 | 10:05 PM
stangkilr's Avatar
Still cannot get them to work. Which fuses do I need to check? I took the drl relay out, changed the dlr fuse to a 25. I also tried it with that one out. Where is the headlight fuse at? Or is their one? Im getting flustered here lol
Old Dec 17, 2008 | 12:12 AM
RickCoMatic's Avatar
Cover-up the Daylight Sensor on the dash.
See if they are being powered by the Headlights-Full Circuit or the DRL's. The Headlight Circuity runs off that Daylight Sensor unless you over-ride it at the Light Switch. Pull-out the **** on the Light Switch and run the lights Manual and see if there is any change.
Intimidator38
Mar 11, 2014 02:19 PM
ShadowX760
Apr 22, 2013 05:32 AM
fordwhupper
Nov 15, 2012 05:51 PM
l0gitech87
Aug 4, 2011 09:28 PM
willeatforfood
Oct 15, 2006 12:00 AM
