impala ss beat my monte ss
Old Apr 17, 2007 | 09:40 PM
red 06 v8 ss's Avatar
Default impala ss beat my monte ss
a guy down the street from me just bought a new impala ss.so we went down to the new subdivision thats empty.and ran them agaist each other.that f-ing thing walked on my 06 ss monte.whats up? i have a new magna flow exhaust (res )deleateand his is stock. that car of his pulls hard.i wasnt late on leaving either . do they have more h.p.
Old Apr 17, 2007 | 10:22 PM
Default RE: impala ss beat my monte ss
[align=center]
ORIGINAL: red 06 v8 ss
[/align][align=center][X(][/align][align=center]Hi Rich, the first thing I would do is take my Monte SS to the[/align][align=center]Dr Auto Tech & have himhook-up the `puter on your 303 HP.[/align][align=center]Something is wrong, got to get your Monte[/align][align=center]checked out & get ready for a rematch.[/align][align=center][/align][align=center][/align][align=center]Some of us get a Slow Dog : ([/align][align=center][/align][align=center]and someget the `Fast Rabbit [/align][align=center][/align][align=center]__________________________________________________ ___--[/align][align=center]Red06 V8 SS[/align][align=center]That Sucks, but I reallyappreciate that you are honest....[/align][align=center][/align][align=center]I hope that your computer in your Monte is just `off, I'd be back 2 the dealer[/align][align=center]or find a good tech tuner : )[/align][align=center][/align][align=center]Please keep the MCF informed on your plans & next line-up[/align][align=center]against the Impala SS.[/align][align=center]I will keep search'in 4 infor & comparsions.[/align][align=center]Good Luck,[/align][align=center]`Space[/align][align=center][/align][align=center]Below are some links about the Impala SS & Monte SS[/align][align=center][/align][align=center]After stepping out from behind the wheel, the driver can’t help being impressed by the SS’s power and its ability to generate astonishing numbers — 0 to 60 in 5.6 seconds, for one. The SS seems to have been created to produce impressive numbers on paper with little regard to driver enjoyment.[/align][align=center]Same HP as Monte 303 HP[/align][align=center][/align][align=center][:-]Click Link [:-][/align][align=center]http://www.caranddriver.com/roadtest...impala-ss.html[/align]
[hr]
2006 Chevrolet Impala and Monte Carlo Reviews:
[:-]Click on link below[:-]
[align=center][/align][align=center][/align][align=center][/align]
Old Apr 17, 2007 | 10:54 PM
76MonteMan's Avatar
Can't explain that one. Both cars have identical engines and both have identical drivetrains. The Impala is also heavier than the Monte Carlo. You should have won that race because of the weight difference.
Curb Weights:
Monte Carlo SS: 3549 pounds
Impala SS: 3790 pounds
Old Apr 18, 2007 | 12:47 AM
04 Intimidator's Avatar
The only thing I can think of is he manually shifted and ran his car hard into the redline. It's kinda dumb on his part to run a brand new car that hard anyway. I would break in the engine first for 500 miles before doing that. If he plans to keep it for a long time, I wouldn't run it hard again until my first oil change.
Old Apr 18, 2007 | 01:07 AM
Yellow_Monte's Avatar
ya Id agree with what 04 said, he just pushed his harder
Old Apr 18, 2007 | 01:57 AM
FlynhghR's Avatar
Actually the Impala with the stock exhaust would have a Torque advantage. Your new exhaust has less backpressure which naturally moves the torque range higher in the RPM range. His car will pull harder at a lower RPM, and doing your racing on the back streets I doubt you got all the way through second gear into third. Third gear is where your car will shine with the new exhaust, because the higher RPM's are sustained for a longer period, where your car has the advantage. I would experiment with some different resonaters, or maybe just a smaller diameter resonater delete. Somethign that has better backpressure will move your torque curve lower in the RPM, so you feel the acceleration earlier, but it will limit the topend hp production.
Run 91 or 93 octane. I'm pretty sure your car will retard timing if it's running on 87 or 89. Ethanol also effectively upps the octane, but also produces more heat. If your car was not fully warmed up where your competitor was this can affect things as well.
Old Apr 18, 2007 | 11:35 PM
2000_BLACK_SS's Avatar
What about traction?
did you spin the tires alot and what did you have your rpm's at the start
Old Apr 20, 2007 | 11:42 PM
Bigg J's Avatar
What FlynhghR said makes sense. It's funny this came up, though, because a little while back, I went up against a dude in an '04 Imp, 3800 like my '05 LT, and he started to pull on me too. I have no clue if his was modded, though. When we got to the red light, all he would say was that it was a 3800.I thought it strange that he would pull on me like that.
Dec 4, 2011 08:47 AM
Mar 23, 2011 01:47 PM
BeachBumMike
Oct 26, 2007 10:45 AM
BeachBumMike
Jan 17, 2007 10:46 AM
04MonteLS
Jun 9, 2005 12:55 AM
