How do i shut Low Tire Pressure light off with
Old May 13, 2012 | 10:11 PM
16With01MonteSS's Avatar
Default How do i shut Low Tire Pressure light off with
Aftermarket Stereo? please help its bugging me badly thanks in advance.
Old May 13, 2012 | 11:13 PM
I use the method in the owners manual. Turn the key to the ON position. Turn on the parking lights (pull out / push in) 3 times within 5 seconds and then shut off the ignition switch. That should get the low tire pressure light to reset. good luck......
Old May 13, 2012 | 11:41 PM
IffyG's Avatar
It's important to note that it's three times in 5 seconds, not three times as fast as you can. If you can't get it to reset, take a stop watch with you and time the 5 seconds out.
Old May 14, 2012 | 01:04 AM
It doesn't need to be perfect, just do it slowly within the 5 seconds, if it's within 3-4 seconds you'll still be fine. If not try it again, you'll probably get it within the first 3 times.
Ulsterman
Aug 12, 2008 02:13 PM
chevyrider08
Apr 29, 2008 10:04 PM
MotorTSki
Apr 20, 2008 11:25 PM
amberblk00
Sep 12, 2007 03:03 PM
rob559
Feb 22, 2007 11:13 PM
