How do I get the rear hubs off? 04 monte
Old Apr 19, 2009 | 04:00 PM
Cori04Monte's Avatar
Default How do I get the rear hubs off? 04 monte
Hello all, I'm trying to do the rear brakes and r&r the rear passenger side wheel hub because the abs sensor is bad. I've searched on here and theres nothing about it. Do I need to just remove the four bolts and thats it? Because it still feels kinda tight. I don't wanan wack on it too hard, I figured I'd get some advice first. Thanks.
Old Apr 21, 2009 | 08:29 PM
Paul1965's Avatar
Yes, the bolts that you see are the ones that hold the hub on to the rear axle. Remove them with the correct size torx bit, then coax the hub loose with a hammer and you should be set. Reverse the procedure (minus the hammer) to install the new hub.
JC Colon
Oct 15, 2014 06:59 PM
Bronco Bill
Mar 21, 2012 09:49 PM
Tomofnnh
Jun 24, 2010 12:10 PM
Xx-007-xX
May 25, 2010 11:33 AM
Viper
Aug 23, 2009 09:45 PM
