Help! Loose Hubs?
Old May 22, 2010 | 12:09 PM
Xx-007-xX's Avatar
Exclamation Help! Loose Hubs?
Hey folks lets see if you all can help me here, I have been sporadically getting the "service traction" "Trac off" and "ABS" warning lights. I got it up on jacks today and there is play in both front wheels/hubs, I grabbed the tire at the top and bottom and wiggled it and it was loose. I would say that the top of the tire would work back and forth about 3/32 of an inch, is there a certain amount that it CAN move that is with in safe standards or do I need to change my hubs? could this be the cause of my problems of the "service traction/trac off/ ABS" light coming on sporadically?
Old May 22, 2010 | 11:42 PM
Sliver's Avatar
I would get new hubs and check your tie rods. Things will only get worse and dangerous.
Old May 25, 2010 | 11:33 AM
alburrito's Avatar
Yes, speed sensor is in hubs and causes Service Traction System message to appear. Hubs like to go out on these cars. Tie rods good idea as well. I did all of this last year. Also get your lower control arm bushings inspected. After I replaced all of the parts I still have lingering vibration issues. Was told by firestone that this causes suspension not to work as well either. Good luck!
izmouse
Mar 17, 2012 08:45 PM
irulesoha
Feb 9, 2011 09:03 AM
Tomofnnh
Jun 24, 2010 12:10 PM
Viper
Aug 23, 2009 09:45 PM
Cori04Monte
Apr 21, 2009 08:29 PM
