Enabling/Disabling Alarm?
Old Jan 5, 2012 | 11:21 PM
DTG's Avatar
DTG
Question Enabling/Disabling Alarm?
so I was reading through my user manual last night, like a couple other people here in the forum that had questions on this, but according to the windows sticker that was on the car when it was bought new it has an alarm, so I continued reading through the manual and found how to set it, so I set it to *on
tried with 1 push of fob, waited around a couple minutes tried to open the door, no alarm, so I relocked all the doors with the fob, 2 pushes this time, waited around for another few minutes while I had a smoke, grabbed the door handle and gave it a pull again, still no alarm going off, so I relock all the doors again, 3 pushes on fob this time, came in the house took a crap, went back out and tried to open the trunk lid, hmm no alarm still lol, any ideas?
Old Jan 9, 2012 | 06:31 PM
02ssLE's Avatar
Doesn't the door have to open before the alarm will sound? Maybe someone can verify that for us..Try locking with the fob, then unlocking the door with your key, and opening it.
Old Jan 9, 2012 | 10:45 PM
nyislanders's Avatar
The door actually has to open for the alarm to go off. This is what you should do to test your alarm:
1: From inside the car, open the drivers window
2: Take the key out and get out.
3: Lock the car with the fob
4: Reach in the window and manually unlock the door
5: Open the door from the outside
If the alarm sounds, then you're good. Just grabbing the handle isn't enough for the alarm to sound. And if you use the key to unlock, as far as I know, that will disarm the alarm. The car knows when you use a key to unlock the door manually and disarms the alarm and turns on the interior lights.
Old Jan 9, 2012 | 11:32 PM
Yup thats how it works but major flaw in the system is you can pop the door handle off & get in with no alarm sounding or if your lock cylinder is wore out anything will unlock it, id suggest ppl check the lock cylinders from time to time with other keys to make sure it doesnt unlock, dont take but a slight movement in the lock to unlock it, mine has this issue so i unhooked the lock rod in the door
Old Aug 9, 2014 | 06:15 PM
Dread04McSC's Avatar
Need help i have a aftermarket and method not working
Old Aug 10, 2014 | 05:30 AM
gprtech's Avatar
An aftermarket alarm would probably work with it's own key fob. Do you know what type it is?
My daughters 2001 had a viper alarm system and remote start installed at come point and then removed. There were no original remotes with the car, and the radio didn't allow programming any, so I installed a new Viper, since the connections were already there. It uses Viper key fobs.
Didn't reinstall the remote start.
Radar Bait
Sep 16, 2013 07:54 AM
Vince
Feb 7, 2011 08:33 PM
thewhitestcarlouknow
Oct 17, 2009 02:29 AM
FourX11gd
Nov 3, 2008 02:06 PM
inssanity21
Oct 22, 2008 09:09 PM
