CheCk EngiNe LiGht and Low Tire Pressure
Old Apr 27, 2008 | 01:56 PM
chevyrider08's Avatar
Default CheCk EngiNe LiGht and Low Tire Pressure
So ive been reading through the post about the P0420 code. Turns out thats exactly what my computer is reading, so how bad is it?...i mean how long can i go avoidin the problem?...and as far as the low pressure light...my fac. radio doesnt even have the tir pres. reset function...n ive tried a million times to do it wit the runnin lights...so i hope someone can provide some answer for me thankz...Laterz
02' on 22's
Old Apr 27, 2008 | 02:46 PM
ExplosiveSoundz's Avatar
Default RE: CheCk EngiNe LiGht and Low Tire Pressure
Have anything aftermarket on your car? How many miles?
Old Apr 27, 2008 | 03:05 PM
just rims thats it...n its got 106,000 miles
Old Apr 27, 2008 | 03:10 PM
then it's either time for a new cat, or a new o2 sensor, but either way, if you don't have an aftermarket system, p0420 is not a normal code to throw...
Old Apr 27, 2008 | 05:22 PM
dustybird3's Avatar
Photobucket
Monte Of The Month - April 2008
The P0420 is the cat. What year is your Monte? If it's an '01 or '02 check out this post https://montecarloforum.com/m_12459/tm.htmMine was one of those and GM fixed it at no cost.
Old Apr 29, 2008 | 03:30 PM
well...i took the monte carlo to the dealership today and they said a aftermarket converter had already been installed...so wat r the chances of it being the O2 Sensor for sure?
Old Apr 29, 2008 | 06:54 PM
dustybird3's Avatar
Photobucket
Probably that aftermarket cat causing it. There's a way to test the O2 sensor but you'll have to do a search on the net. I found at one time when Advance said my O2 was causing the P0420 code and was researching it. Most everything I found said that if it's the sensor then it will throw a code for the sensor and not for the cat.
Old Apr 29, 2008 | 07:10 PM
well my instructor said it might be the O2 sensor to...i just dont want to waste the money...but i will do some research
Old Apr 29, 2008 | 08:58 PM
rysZ34's Avatar
Well it isn't a waste of money. There are only a few things that cause this code. A cat and an O2 sensor...it's just a matter of which sensor is throwing the code, that will be the challenge. Good Luck.
Old Apr 29, 2008 | 10:04 PM
dustybird3's Avatar
Photobucket
Well, if it helps any, I've heard that it's a good idea to replace them at 100k miles anyway. hmm, I guess I really should replace mine too.
dcnaser
May 19, 2013 01:55 PM
milrlyt
Aug 9, 2011 12:00 AM
Ulsterman
Aug 12, 2008 02:13 PM
MotorTSki
Apr 20, 2008 11:25 PM
amberblk00
Sep 12, 2007 03:03 PM
