99 Monte Carlo Brakes
Old Jul 28, 2008 | 09:52 AM
cbr600rrnut's Avatar
Default 99 Monte Carlo Brakes
Hey gang
Rear brake shoe spring is a 1 piece design. Do I need a special tool or can I remove and re-install it with channel locks or some other type of pliers? Also the radiator low coolant sensor is defective. Is it fairly easy to replace?
Thanks
Kelly
Old Jul 28, 2008 | 07:25 PM
rysZ34's Avatar
Default RE: 99 Monte Carlo Brakes
Kelly,
I have a Z34 so I have rear discs so I can't help you with that. The coolant level sensor is either in the bottom of the overflow tank or at the bottom of the radiator....both places are fairly easy to replace to my understanding.
Old Jul 30, 2008 | 05:26 PM
I connected my scan toool and no codes are set? Any thoughts? I am thinking possibly a bad ground. I will follow the troubleshooting guide in the GM manual.
Old Jul 31, 2008 | 07:23 AM
I unplugged the sensor and the light is off so therefore my dash is OK and the issue is the sensor. The overfill bottle is up to level as the intake doesn't leak...yet! LOL.
ORIGINAL: petty
You might just take it to the nearest mechanic and fork it out about $150 to $200. If you had a low coolant light come on, don't worry unless you are 50 miles from nowhere. Check to see if your coolant is full.
Old Jun 2, 2010 | 03:06 AM
khno.29's Avatar
I use a pair of needlenose visegrips. make sure the are tight and have good claws because they will slip.
Old Jun 2, 2010 | 11:53 AM
nitehawkjcb's Avatar
I just used a screwdriver to reattach the spring.
jmarchand
Nov 5, 2012 08:38 PM
SLY_Showtime
Jul 21, 2012 07:07 PM
vlstokley
Dec 13, 2011 07:35 PM
kennyjohn
Jun 15, 2011 08:29 AM
slinkeey
Jun 27, 2010 12:33 AM
