2 quarts of oil between every oil change?
Old Sep 25, 2012 | 10:13 AM
MAMONTE's Avatar
I agree completely. But prior to knowing he had 67K on his car, it said in the thread that there was no leaks at all...It is possible to burn that kind of oil, maybe if it wasn't well cared for and had over 200K on it. :P Not the problem though...
Old Sep 25, 2012 | 12:15 PM
blackbeauty89's Avatar
Check around your intake plenum. Most common issue with GM V6 engines is intake gaskets. If you have a plastic engine cover, just twist off the oil filler neck and pull off the cover
Get a flashlight and look all around the plenum for oil. It could very well be collecting up there.
Old Sep 25, 2012 | 03:04 PM
My car has a slight valve cover leak and I never see any oil on the ground but on my last oil change I noticed that one of the covers under the motor was full of oil.
dcnaser
Mar 25, 2012 07:40 PM
drmrgal
Apr 8, 2011 05:11 AM
tridski
Mar 1, 2010 03:48 AM
70monte1
25
Jan 19, 2010 09:04 PM
RocknSS04
Apr 16, 2008 08:44 PM
