2 quarts of oil between every oil change?
Old Sep 24, 2012 | 06:49 PM
mstrmysterious63's Avatar
about to hit 67k
Old Sep 24, 2012 | 08:28 PM
blueSS's Avatar
Originally Posted by mstrmysterious63
about to hit 67k
wow mine is at 48,000 and I never have to add oil between oil changes. Gotta be burning it somewhere
Old Sep 25, 2012 | 05:36 AM
Originally Posted by MAMONTE
as well as bumping from a 5W-30 to a 10W-40 oil, and see if that helps.
no! artificially raising your oil pressure is NOT a good idea lol
Old Sep 25, 2012 | 06:21 AM
I know when the oil pressure switch fails, it will seep oil out (really bad it will spray oil). If you have a 3400, look above the starter towards the driver side. On a 3100/3400 that oil switch is super cheap and easy to change (takes me 5 minutes). Also, if you are running a 3400, if you have not had the LIM gaskets changed, unusual oil loss has been a symptom I've seen before (I could tell you stories of the original 3100 TSB's I've read).
If the engine is covered in grime/oil, get a can of engine degreaser and degrease the thing, otherwise it's tough to distinguish from new or old residue.
Old Sep 25, 2012 | 08:51 AM
MAMONTE's Avatar
about to hit 67k
That's way to low of mileage for you to be burning 2 quarts in between changes. You have other problems...now you need to find them.
Old Sep 25, 2012 | 08:54 AM
MAMONTE's Avatar
Blah Blah...if it was a worn out engine, with high mileage...it wouldn't matter. But you are right in not doing it to a low mileage engine such as his. But truthfully, even then, it wouldn't damage anything by sticking 10-40 in a car that requires 10-30 or 5-30...You might loose a few MPG, that's about it.
Old Sep 25, 2012 | 09:06 AM
I use Lucas in all my high mileage vehicles..
Old Sep 25, 2012 | 09:10 AM
I use 5w-30 in my 186,000 mile car and I only have to maybe add .5 qt after 3 months?
Old Sep 25, 2012 | 09:39 AM
MAMONTE's Avatar
I use 5W-30 in my 164K car as well, and have to add maybe .25-.5 quarts in 8K. Which is why I say, there is definitely bigger problems if it's going through 2 quarts.
Not all engines are taken care of as well as our Mike...
Old Sep 25, 2012 | 09:47 AM
Which is why you need to find the problem and not just drop in a higher velocity oil
Which is my whole point from earlier haha.
