Info: TSB 03054B - 3800 Fuel Pressure Regulator Recall/Upper Intake Explosion
Old Jan 17, 2025 | 08:25 AM
Default TSB 03054B - 3800 Fuel Pressure Regulator Recall/Upper Intake Explosion
Attached is a PDF of GM's TSB 03054B - 3800 Fuel Pressure Regulator Recall. This is fairly old information these days, but given the age of these vehicles, it is still possible a vehicle out of the recall range could experience this issue. If you have a L36 3800 and the upper intake explodes and you are repairing this issue, replace your fuel pressure regulator during this process.
A common/easy check many have done is remove the vacuum line from the Fuel Pressure Regulator, inspect it for signs of wet fuel OR odors of gasoline. If this is found, many have reported this to be a common sign that it has failed and is now allowing fuel vapors into the upper intake.
Notes from the TSB/Recall:
GM has decided that a defect which relates to motor vehicle safety exists in certain 1998-2000 Buick Park Avenue, LeSabre, Pontiac Bonneville; 1998-99 Oldsmobile Eighty-Eight; and 2000 Chevrolet Monte Carlo, Impala model vehicles equipped with a 3.8L V6 (RPO L36 - VIN Code K) engine. These vehicles have a much higher than usual rate of fuel pressure regulator diaphragm leaks. A leak can allow fuel to enter the intake manifold through a vacuum line. In low battery conditions, if the engine does not start when cranked, the fuel from the leaking regulator and a mistimed spark can cause a backfire. The backfire can rupture the intake manifold, causing a loud bang. The rupture of the intake manifold can displace a fuel line, pulling an injector out of place, and causing a fuel leak. If there is an ignition source, a fire can result.
Inspect the engine fuel rail:
• If the fuel rail has a DELPHI manufacturer's label, refer to the appropriate service manual and replace the engine fuel pressure regulator. Use labor operation V1082 to close the recall.
• If the fuel rail has a BOSCH manufacturer's label, do not replace the fuel pressure regulator. Use labor operation V1117 to close the recall.
KKrueger24
Aug 30, 2016 10:06 AM
armando b
Feb 16, 2015 01:55 PM
CBroadfoot
Jul 24, 2014 04:02 PM
yeyeee01
Dec 9, 2011 07:46 AM
kennyjohn
Aug 24, 2011 04:23 PM
