1999 monte carlo fuel pressure regulator
Old Jun 8, 2011 | 09:06 PM
kennyjohn's Avatar
Default 1999 monte carlo fuel pressure regulator
How do I change a fuel pressure regulator on a 1999 monte carlo?
Old Jun 9, 2011 | 06:17 PM
DerEin's Avatar
relieve the fuel pressure and lift the fuel rails off. Once you do that there is a snap ring on the regulator itself (they sell snap-ring pliers if you fancy a pair). Disengage the snap ring (or whatever verb you would like to use) and simultaneously twist and pull the regulator off. There is a screen there that you are recommended to clean off with something like compressed air as well.
Old Jun 10, 2011 | 03:18 PM
kennyjohn's Avatar
Thanks
Old Aug 24, 2011 | 03:32 PM
tjwr1058's Avatar
Have to change fuel pressure regulator on 1998 monte carlo could I get a picture of its location and how to relieve fuel pressure? Thanks
Old Aug 24, 2011 | 04:23 PM
nitehawkjcb's Avatar
On the fuel rail there is a Shrader valve, just push the pin in the middle of it after removing the cap. Why do you think the FPR is bad?
Dottie
Nov 1, 2014 11:08 PM
CBroadfoot
Jul 18, 2014 08:25 AM
yellowmonte
Feb 23, 2010 08:38 AM
shingding88
Feb 3, 2010 09:55 PM
jts01ss
Oct 20, 2008 09:01 PM
