Guide: How to reset low tire pressure monitor
Old Jul 25, 2017 | 04:55 PM
  #31
russehrgood's Avatar
I did not know that my 02 Monte SS had a TPMS until the low tire pressure warning popped up on the dash last week. I went to the nearest free air and checked the tires, low and behold the right front tire was down 5 lbs. I added the five pounds and reset the low tire warning as per owners manual. I went to my tire store and had a nail in the tire, had it fixed. Apparently the tires don't have tpms sensors in the tires but use the speed sensor in the wheel hubs to measure difference in wheel speed to detect lower air tire pressure. I checked all the tire pressures a few days later and four different psi's so adjusted all to the factory 30 psi, going to have some choice words with my tires store on the next visit.
Old Jan 12, 2020 | 04:31 PM
  #32
Robert Heun's Avatar
Default Tried
in my 03 monte i took the stock radio out so i used the light switch to reset mine
turn key to on position and quickly pull the light switch out to the parking lights postion and push back in and do this 3 times
worked everytime
Tried this and it worked, really happy to not have any dash lights on 👍
Old Oct 20, 2020 | 04:12 PM
  #33
GrayGhost1951's Avatar
Default Newer wheels
50 max means when they are hot, air inside expands. 32 is for the cold pressure run. I would run that, because the overinflation could just run out the middles of the tires and not the sides and you'll get barely any life out of them.
So I am getting some wheels off a late model Impala,and of course it has tire sensors. Any way to make these work with a 2005 MC? Since it doesn't use a position sensor I gather it works when one tire is 5 pounds lower than the others?
Old Oct 20, 2020 | 04:27 PM
  #34
No way for those tire stem sensors to work with your car, it will use the wheel hub still.
Old Oct 20, 2020 | 07:22 PM
  #35
2005 Chevrolet Monte Carlo
Item may differ from photo
Larger Photo Email A Friend
Our Price: $62.00
Sale Price: $32.98
Manufacturer Chevrolet
Model: Monte Carlo
Availability:: Usually Ships in 24 Hours
2005 - 2007 Chevrolet MONTE CARLO TPMS Sensor Schrader 15268606
0Reviews
So what is the above from? Sorry it's not a better pic.
EDIT: I found this tidbit of information.
2005 Chevrolet Monte Carlo SS Supercharged
2005 Chevrolet Monte Carlo SS Supercharged is equipped with Tire Pressure Monitoring System (TPMS).
Front Tire: P235/55R17 98W (30 psi)
Rear Tire: P235/55R17 98W (30 psi)
Old Oct 21, 2020 | 08:11 AM
  #36
Probably just an error with the years.
In 2006 they switched to the valve stem style
All of our 2000+ cars had a TPMS system technically. The car monitored the revolution of all of the tires, and if one was off it was assumed to be low on air.
Old Oct 21, 2020 | 03:10 PM
  #37
I may just buy one off Amazon so I know. Miss having that feature.
What cat do you run? Anything special? This thing is stock so I don't see a need for something high flow. Do you run a resonator?
Old Oct 21, 2020 | 03:36 PM
  #38
I use a hollow one, and have it completely tuned out of my car. I drive MAYBE 2000 miles a year and am exempt from emissions testing. And yes, I have a GMPP cat-back exhaust, which is an unbranded Magnaflow system that GM partnered with and it runs a shorter 18" resonator.
Old Oct 22, 2020 | 07:09 AM
  #39
Default Emissions
I will have to look into that about emissions. I guess you have to do a form that states drive less than a certain amount of miles? I live in Tennessee. It may pass anway if I have a cat. Thanks for the info.
Old Sep 21, 2021 | 07:10 PM
  #40
craig32's Avatar
Again, I realize this is an old thread, , , , but none of that worked for my car. I got some Firestones on the front that are constantly going soft, but usually both are going down and don't set off the sensors. I had only one go down and the sensor tripped the light, the radio wasn't the right one to work in my car (didn't have the option on it) and I tried at least a dozen times with the light switch, and nothing worked. I just unhooked the battery for a few seconds and that does the trick. I try to do it at noon so I don't have to reset the clock!)
