Guide: How to reset low tire pressure monitor
Old Jan 10, 2011 | 12:09 AM
Justin's Avatar
Originally Posted by 04 Intimidator
Justin - There is a faster way to do it without the radio.
Start your car.
Pull the headlight *** back one click and push it back in. Repeat the pull/push 2 more times within 5 seconds and the dash will beep and the tire light will go out.
its been awhile since last on, but i tryed that too and it doesnt work for me either. i can get the light to shut off if i unhook the battery for a min then when i hook it back up the light is off. so why is it that the light switch or the radio wont reset the light when it comes on?
Old Jan 29, 2011 | 10:55 PM
ladybridgeport's Avatar
I have an aftermarket radio, so instead of putting the old radio in and resetting it. I turn the ignition on, not starting vehicle, then depress the gas pedal 3 times. It also resets your oil life as well.
Old Feb 22, 2011 | 01:34 AM
MrChyes's Avatar
i tried this on my stock radio in my 04 ss...worked...no more tires retardation lol
Old Mar 10, 2011 | 06:26 AM
Dastankos's Avatar
Might be un-helpful but I'm trying to get my 5 post minimum out of the way cause I'm a new guy. Instead of getting a new stereo you can get an adapter that plugs in the back of your stock stero for around $215. I did this in my '04 Dale Jr. edition because to keep my steering wheel controls and get a decent stereo it was gonna be about $400. Best Buy has these and the install is included in the price. You get a hook-up for an iPod, a normal AUX chord and it also gives you HD radio. I did this not just for the cost but to also to keep control of all my options through my radio. So if you got the extra cash this is a much better way to go than a new stereo. To select between your radio/xm/cd/ipod/aux2 all you do is push the band button. It's a pretty nice piece of technology.
Old Mar 22, 2011 | 02:31 PM
HEMI_DAD's Avatar
I guess it will say low when you have too much air.
The stock pressure vs "20" pressure. Is there a way to tell computer 40-45psi is OK?
Old Mar 22, 2011 | 03:23 PM
It will say low if one tire is 5 pounds less than another.
Old Mar 22, 2011 | 04:58 PM
Chibi, I think you are answering a question I was gonna ask. My stock prressure is suppose to be 32, my Falkens are 50 max, so I run them about 45. So as long as they are all within 5 it will work? Really doesnt matter but I have one that goes out while highway driving. I think I will just save up and order 4 new since they are all about through their lifespan I think.
Old Mar 22, 2011 | 05:13 PM
50 max means when they are hot, air inside expands. 32 is for the cold pressure run. I would run that, because the overinflation could just run out the middles of the tires and not the sides and you'll get barely any life out of them.
Old Mar 22, 2011 | 11:36 PM
Curtis24682007's Avatar
I tried the gas petal method with no success. I will try the light switch tomorrow and if that don't work will do the radio method. Right now my factory radio is just OK, still debating on wether I should change out with a Sony. Is there anyway to keep use of the radio functions without spending a ton of money?
Old Mar 23, 2011 | 06:32 PM
xxtheshockerxx's Avatar
RED DEVIL
in my 03 monte i took the stock radio out so i used the light switch to reset mine
turn key to on position and quickly pull the light switch out to the parking lights postion and push back in and do this 3 times
worked everytime
