Repair Guide: Drive Axle Replacement
Old Nov 13, 2013 | 09:02 PM
Radagast the White's Avatar
Bump. I'm probably going to have to replace my CVs soon too. You seem knowledgeable and I am a novice. How long did it take you?
Old Nov 13, 2013 | 11:19 PM
bfenty's Avatar
Also-aftermarket vs OEM. I've read many horror stories of aftermarket axles failing soon after install, but not entirely sure if that was someone who did a bad job installing, a one-off situation, or a bad overall part
Old Dec 28, 2013 | 09:56 AM
Monte_Man04's Avatar
I am at step #18 and I have two questions.
How exactly did you get the leverage to pry it off utilizing the transmission housing? I have a small pry bar, and a crow-bar and neither has a fulcrum point on the trans housing to pry off of...
and where would you place the hammer strike to give it the most effective love tap?
Thanks!
Old Apr 10, 2014 | 07:37 PM
carfan770's Avatar
Just curious, when you pulled the old axle, did the circlip come out with it? If it didn't come out withe the old axle, are you trying to put the new axle in with a new circlip already on it?
Old Apr 11, 2014 | 01:27 PM
Both my axles came out with the circlip on them and the new axles went in with new clips too. If it doesn't come out with the axle do some fishing around in there. It is possible that your old able never had one to begin with. When I replaced my thermometer I found that there wasn't an old one to remove. Never underestimate the previous owner
Old Jun 14, 2014 | 11:53 AM
upperdeck521's Avatar
I'm new here and if anyone could help that'd be great, I'm having some troubles taking my front passenger axle off. If anyone knows that's be great, i can't seem to upload the picture of the 95 monte z34. It's just not pulling out
Old Sep 29, 2019 | 01:30 PM
Sabrina Griffiss's Avatar
Default CV axle
Need to remove my cv axle but I need the easiest steps possible to do so please!
v6racer
May 23, 2017 11:58 AM
KingWord
May 6, 2015 12:43 PM
izmouse
Mar 20, 2012 03:29 PM
jasonsmith
Jan 22, 2012 01:44 PM
DerEin
Aug 8, 2011 11:56 AM
