CV Joints
Old Mar 19, 2011 | 10:20 AM
DerEin's Avatar
Default CV Joints
I think I may be changing the CV Joints, CV axle assembly..etc.. ,whatever it is that you call it in your particular group of friends or family, on my 99' Z34. I was curious if anyone else had done this and knew of any particular hang-ups or tips.
For instance I changed my water pump 3 or 4 weeks ago and it took a few spats of rage to realize that I had to remove the power-steering pump to get the final bolt out of my water pump to remove it.
Just trying to think ahead and avoid any unnecessarily busted knuckles.
Old Aug 6, 2011 | 02:15 AM
oliver's Avatar
Why do you think you have to change the CV Joints, CV axle assembly and others? Has anyone advised you to do so? Replacing those parts is not easy you might need the assistance of a mechanic. but if you're a DIY type of person, it may not be a daunting task for you
Old Aug 8, 2011 | 11:56 AM
nitehawkjcb's Avatar
It's easyyyy
Break loose the axle nut (you're gonna need a big socket and a breaker bar)
Take off the rim
Unbolt the 4 bolts holding the wheel bearing/hub in place, remove wheel bearing/hub
Get a pry bar and stick it between the axle and transmission and pry it out (check the tripot that's sticking in the transmission, sometimes there's a groove on it you can use with your pry bar to pull it out)
Work it out of the transmission, wiggle back and forth, and pull. Replacement is opposite of this, just make sure there's a snap ring on the end of the axle where it goes into the transmission, unless yours is in the transmission (which it might be)
Good luck
zillatattoo
Oct 28, 2011 09:29 PM
J-Bob
Apr 9, 2010 03:24 AM
jay26
Aug 3, 2008 05:36 PM
Nathan
Nov 1, 2006 03:58 PM
