Repair Guide: Battery Replacement
Old Feb 26, 2010 | 04:25 PM
be careful when putting the stabilizer bar back on that you dont strip out the grooves, i made this mistake, i just chopped down the bolt so it didnt make a big deal but its really a pain
Old Feb 26, 2010 | 05:37 PM
monte07's Avatar
hay mine is a 10mm bolt and yes it is a top conect battery cable's and a top style battery ;P i am glad though i always had bad luck with the side mount batteries with the conectors breaking on the battery nuts
Old Feb 26, 2010 | 09:28 PM
montes my python's Avatar
Know what, your right, I was thinking of the older GM side terminal battery bolts, Sorry
Old Jun 10, 2010 | 05:14 PM
Proteus157's Avatar
@Taz - great post on the basics of battery replacment. I just did my 05 SS and I think you missed a few steps:
Not sure why mine was a PITA...but I had to take the cap off the fuse block that is attached to the wheel well, unbolt the battery harness from the fuse block, undo some blue connector, push the harness down in the engine compartment... that was just getting the stuff out of the way.
Then I had to slide the battery sideways, rotate 45 degrees, and gingerly stand it on end to get it past the fuse block...without breaking it.
Major obstacles were the fuse block and core support behind the headlight.
Again, not sure why mine was so painful, but I'm glad I bought a battery with a 7 year warranty...
Old Dec 9, 2011 | 03:42 PM
Zeke's Avatar
Just to add something here ...
I just wintered my 2003 SS, & removed the battery for the winter storage ... Obviously I removed the bar & the wedge mount. Then upon removal, I could NOT get it out without removing the radiator cap.
What an oddball.
Ugh.
Old Dec 9, 2011 | 07:01 PM
Zeke's Avatar
I know, I know. First *new* post in nearly a year and a half, but I am new here, & am slowly making my way through the nooks & crannies of MCF.
I poke my head when I feel appropriate ... & when I feel I will not get it ripped off.
Old Dec 9, 2011 | 11:25 PM
What an oddball.
Ugh.
The radiator caps on SS and LS models are in the same place aren't they? that's weird.
Old Dec 10, 2011 | 12:01 AM
SupplySgt's Avatar
Lol it's funny that this thread pops up. I changed my battery in the dark and cold a little over a week ago. Wasn't fun but I'd done it before on W-bodies and so it didn't take me but 15 minutes. Make sure you don't knock the hose leading to your coolant overflow tank loose from the it. I did that and didnt' realize it till I popped the hood after it was light again (didn't have a flashlight handy I did it all basically blind)
cnogood
Sep 20, 2014 04:16 PM
70monte1
Jun 14, 2012 05:12 AM
kart74
Sep 24, 2010 01:50 PM
DCfla
Aug 20, 2009 01:26 AM
thorspower
Aug 26, 2007 01:37 PM
