What Pulley Size can You Run? The Write up
Old Feb 9, 2008 | 09:24 PM
ParrottZ34's Avatar
Photobucket
Default What Pulley Size can You Run? The Write up
Noticed some of you guys had questions relateed to what size pulley you can run, so i found this for you guys, i hope it can be of some good use for some of you.
This should be a quick down and dirty to the ever present question. When can I run a 3.4, 3.25, 3.0 etc.... Take into account this write up will be on the more conservative side and I think everyone will agree that this aplies to 95% of GTP's. Obviously that 5% applies to people with already hurt motors or if you have 150k miles, have gone 10's of thousands of miles between oil changes etc... you may want to rethink modding at all and start fresh. With this list you should be knock free, however its always a good idea to either buy a scantool or join one of your local chapters and find someone close by with one to scan for kr, however like I said this list is designed to almost guarntee 0 KR.Anyone please feel free to addin suggestions or comments and I will adjust this accordingly.
Well start with the 3.4 pulley as it usually starts the majority of these questions. Below you will find a list of supporting mods that should be in place prior to installing that 3.4. Can you get away with less? Possibly. Have people gotten away with less? Yes. Do you want to take the chance? Enough said.
1. PCM- standard v 1.0 will suffice at this level.
2. CAI/FWI- Cold Air Intake/ Fenderwell Intake, you can build your own or purchase one from a vendor.
3. Ported Exhaust Manifolds/ Headers/ ZZP Powerlog- your choice, at this level Pems or the Powerlog are fine, if your planning on further modding later you will need headers, only you know your budget.
4. 3" Downpipe- Crushbendt which most exhaust shops will do is unadvised, preferable to purchase an aftermarket from one of the vendors.
5. 1-2 Heat range colder plugs. i.e Autolite 104's or equivelent gapped in the .050-.055 range
6. Ubend delete- just after the cat, most exhaust shops will be able to remove this and put in a straight pipe.
Thats it, doesnt sound too hard right? Fortunatly your reading this, back when alot of us blew our motors there was no such write up and no such guidance. These 5 items are considered necissary, of course you can change your thermo to a 180 unit, also wouldnt hurt. Also quite a few people add a set of 1.9 ratio rockers to that list. If you plan on staying at this mod level, I agree, add the rockers, if your planning on continuing on in the quest of more speed and wont be at this level for very long skip the rockers.
Now onto the 3.2-3.25 Pulley. Obviously this is going to take more extensive supporting mods. Add all from above and include:
1. Camshaft- take your personnal pick, do a search these have been compared time and time again. Addin supporting components, i.e stiffer springs, new pushrods, check with the vendor for individual needs.
2. Ported and Polished heads, larger valves- check with the vendors on this one, will be your best bet to invest in a stage 2 or 3.
3. Headers- if you had Pems before your dangerously close to being out of their level, sell and get some headers.
4. Larger Throttle Body- again these have been compared, take your personnal pick.
5. 2-3 heat range cooler plugs, you can stay with 104's but may need to switch to 103's
6. Retuned PCM to add in the cam and free flowing heads etc....
3.0 Pulley needs extensive mods, and honestly you shouldnt even be considering if you have to read this, but just in case take all from above and add:
1. High flow Cat
2.Cat-Back system
3. 42.5# injectors
4. Upgraded fuel system
5. Stage 4 heads
6.Powertuner/HPTuners or some other means to custom write onto your PCM during a dyno session.
Now yes notice I didnt say anything about Intercoolers in any of those combinations. Either a Short Stack or Full size intercooler obviously
Old Feb 10, 2008 | 01:12 AM
Default RE: What Pulley Size can You Run? The Write up
Thats the post from CGP's L67 section right?
I do have a couple things I would like to add to it.
-The first is- if you have a higher mileage- or more knock prone car, then chances are that you may need 1.9: rockers to run a 3.4" pulley.
-The second is the mods to run other pulleys. I personally think its retarded to say you'll need a cam, headers, and $2000 heads to run a 3.0" pulley. That mod list to run a 3.0 is probably $4-5k. IMO, its way cheaper to do an intercooler. I understand he's trying to say that you want an engine that can run knock free on its own (so you don't have to worry about the IC pump failing and torching the engine)- but you could seriously drop $3-4k off that price, then spend $750-$1000 to get a full size IC and make the same power for a lot less money.
I don't really think running an IC is a bad way to do it- if you look at the cobalts, cobra's, etc they have factory water to air intercoolers. The key is to build a proper system (preferably pressurized, closed)- and to buy a reliable pump. If you're super worried about a pump dieing, they make a 'pump detect' kit that lets you know if the pump is running or not- or heck, ditch your ac compressor and fab a mechanical IC pump in its place. But IMO if the factory supercharged cars are running electric pump IC systems- it can't be that bad in the aftermarket.
-The third is he is pretty non-descriptive about an 'upgraded fuel system'. Honestly from what I've seen- most people upgrading their fuel system do a fresh fuel filter- drop in a walbro/racetronix pump, and do injectors (42.5 or 65 #/hr depending on how far you plan to go).
It seems like only the hardcore drag cars are going to either a fuel cell (or an external pump on a stock tank) with upgraded lines, and such.
Even with the fuel rails- it seems like the only people who really change those out are the ones running an IC that don't want to cut their stock lines up to clear the new blower height. Just wanted to clear that section up.
Old Feb 10, 2008 | 08:55 PM
04 Intimidator's Avatar
Doa search. I have this posted here about 4 times now with annotations such as getting a scanner as you still can't safely run the pulley size with the mods listed.
Old Feb 10, 2008 | 09:06 PM
Here is one of the posts I threw up last year regarding people not scanning. Read the second post for a ton of additional info
https://montecarloforum.com/m_31160/tm.htm
Murray137
Oct 16, 2012 07:49 PM
Yellowjacket
17
Oct 1, 2012 07:58 PM
Submariner
25
Jul 2, 2008 06:18 PM
86Ls
Mar 12, 2008 04:26 PM
monteriderLS
Aug 7, 2006 02:53 PM
