What does this plug into?!?!?!
Old Jul 9, 2011 | 06:49 PM
aceofmontespades's Avatar
Default What does this plug into?!?!?!
i just replaced my starter now my car is completely dead in the water where as before the power would at least turn on. i think i popped this out while working on it but i cant find where it goes back into. nothing happens when i turn the key, no starter, no fuel pump, not even my radio.
Old Jul 20, 2011 | 09:13 AM
06-montelt2's Avatar
That kinda looks like its for a headlight? Im not quite sure. Headlight/foglight, check everything that that cable can physically reach.
Old Jul 20, 2011 | 10:24 AM
03SSLE's Avatar
Is there anything plugged into this connector?
Old Jul 20, 2011 | 10:56 AM
Overdose666's Avatar
Probably not the best advice, but if it can reach a plug and fit into it, it most likely goes there, the majority of the connectors have slightly different shapes to keep you from plugging it the wrong one.
Old Jul 20, 2011 | 11:28 AM
mrl390's Avatar
Thats the washer fluid pump wiring.
Old Jul 20, 2011 | 11:54 AM
I have to agree. I've worked mostly on GMs, so I'm not sure if it holds true on other manufacturers (I would think it would), but they make these connectors pretty idiot proof (unless you are the guy who wants to force the square peg into the circle hole).
Cowboy6622
Feb 6, 2012 10:56 AM
dickie34
Oct 15, 2008 12:51 AM
BeachBumMike
Aug 15, 2007 07:06 PM
impalamonte
33
May 2, 2007 11:38 PM
Sparkplugs.com
Dec 7, 2006 10:45 PM
