weird noise need help
Old Dec 1, 2011 | 06:36 PM
Zmonte34's Avatar
Default weird noise need help
i have a 96 monte 3.4, i just did the timing belt **** 3700 miles ago and now ii have a howling noise coming from the front cam area and im not sure what it is if anyone can help that would be great i need to figure out whats going on asap.
Old Dec 1, 2011 | 07:45 PM
It could be a belt noise, a bad pulley, a bad bearing in the Alternator or something in the power steering system. I would say with the motor off remove the accessory drive belt and spin each pulley. Also check the alignment of all the accessories. I had a slightly bent power steering pulley and it was putting pressure on the Alt bearing. After a week or two it would squeal and then the belt would break.
Old Dec 2, 2011 | 05:19 PM
Zmonte34's Avatar
found out it is the ac pump so now i have to find one on saturday and fix it this weekend so my wife can start her new job
Krueger539
Mar 31, 2014 06:16 PM
owens91
Dec 13, 2012 11:55 PM
BD
May 4, 2007 02:56 PM
sinceire
Apr 10, 2007 03:50 PM
Ca$$e
Jan 27, 2006 03:48 PM
