Tranny fluid/filter change & weird noise
Old Apr 20, 2007 | 11:28 AM
BD's Avatar
BD
Default Tranny fluid/filter change & weird noise
What tranny fluid seems to be the best and does it really take 7.8 quarts like the book says? I have a 04 3.4 with 64,000 miles. My tranny makes a weird scraping/grinding noise when its manually shifted into first and sometimes in first gear in (D) but not all the time. Any ideas?
Thanks
Old Apr 20, 2007 | 11:47 AM
wiz kidd's Avatar
Default RE: Tranny fluid/filter change & weird noise
hey welcome to the site
7.8 quarts would be if you do a complete flush..which most people dont..they just drop the pan and fill it up again...but this doesn't empty the entire system(doesn't empty the torque converter)...just about 1/2 of it...so you will need about 4 quarts
and i would reccoment royal purple max atf fluid...this is what i will run when i change mine...i'm already running their oil since i got the car
Old Apr 20, 2007 | 12:44 PM
Mrrench's Avatar
Dexron VI is the new trans fluid
You can use it in older vehicles, it is combatable with all other dexron fluids.
Old May 3, 2007 | 09:48 AM
davesbedroom's Avatar
Is the pan gasket reusable?
Old May 3, 2007 | 12:49 PM
Mrrench's Avatar
gasket should come with the filter
You should always replace a gasket after it has been used
Old May 3, 2007 | 06:35 PM
derrel96ls's Avatar
remember you must change the o ring inside the filter or in about 2 weeks youll have to flush your system again.
Old May 3, 2007 | 07:24 PM
Anyone know thetorque specs for the pan bolts? ACDelco part number for the filter would be great too
2004 SS supercharged 3800
Modern cars have plenty of reusable rubber gaskets, last transmission I worked on had a reusable rubber gasket. Cork andRTV sealantis the way of the past.
Rubber and proper torque for the win.
Old May 3, 2007 | 11:35 PM
derrel96ls's Avatar
ive wroked on a lot of cars and ive alays had to change the gasket, but anyways everytime you buy a new filter it gives you a new gasket so why wouldnt you change it anyways. Just to be safe
Old May 4, 2007 | 12:32 AM
2000_BLACK_SS's Avatar
When i did mine a month ago i had a gasket that i re-used because it was ribbed and it was also metal with a ruber coating on it and the directions said that came with the new filter said to re-use the gasket if it was like the one i had.
Old May 4, 2007 | 02:06 AM
derrel96ls's Avatar
really???? b/c i have a 01 grand prix, my mom has a 2007 town and country, and my sister has a 05 turas, and ive always had to change the casket, but i guess its different with you car. But i could be wrong but either way if it comes with a part wouldnt you use it?
