Water/Meth kit here!!
Old Mar 10, 2010 | 08:43 PM
BUDDZZ's Avatar
Tuning is a MAJOR key in these kits but like I said you dont NEED it. When you tune with these kit's thats when they come to life and really shine. Right now I might raise it 1-2 psi no tuning for now thats it. My motor and trans cant take it right now but the trans is next to come.
Old Mar 10, 2010 | 08:50 PM
mak330's Avatar
wow yall are serious.
so when you see your temp gauge go up, you press a button or is it contant?
with all the money your spending you could drop a v8 in there.
Old Mar 10, 2010 | 09:35 PM
Has nothing to do with your coolant temps. This has to do with cooling the intake charge- most of the kits I've seen have either been triggered off a WOT switch, a pushbutton, or a MAP switch. I don't like the WOT style because it turns on only when you reach wide open throttle, and you can be making full boost before that- especially on a hill. Same thing with a push button/manual switch- you can forget to turn it on.
I like the MAP switch style best because it turns the pump on when you make a certain preset amount of boost (say 1 psi)- so that it functions when you're flooring it, or just using a lot of gas going up a steep hill. Plus, it makes it more consistent (assuming you remember to keep the tank filled)- so you can tune easier (because you know it will always kick in at a certain point).
Honestly, these kits are pretty cheap- on the absolute cheapest end, I've seen people rigging up setups with cheap pumps off ebay designed for other purposes, using their windshield washer tank, and just running a simple push button switch- and having a whole setup for under $100.
Even the 'normal' kits only run $300 or so- much cheaper than an intercooler with much of the same effect.
Old Mar 11, 2010 | 05:33 PM
BUDDZZ's Avatar
Thanks everyone had a good chat with u guys on this topic. I'll have more pics and some results up in the next couple months, the cars in storage now so its not going anywhere's for a while. Thanks again
03vaderSS
24
Oct 24, 2014 01:25 PM
Ace25
Jun 19, 2013 08:38 AM
Frosty LS1
Aug 24, 2009 02:14 PM
Brooke
Oct 17, 2007 04:35 PM
