twin charging
Old Jul 1, 2010 | 09:58 PM
  #31
Chevy Commando's Avatar
https://www.zzperformance.com/grand_...=411&catid=109
2. What is the twin charged configuration?
This setup is made for running the blower and the turbo. It uses a different style of exhaust housing on the turbo and works with supercharged or symetrical cams. It requires an intercooler below the supercharger. This setup is recommended for running anything larger than a 67mm turbo. It works well with lower stall converters and can spool up to a 80mm turbo. We ran this setup on our 9 sec street grand prix. It comes with electronics to open the supercharger bypass when the turbo spools.
One of the benefits of this setup is that it allows people with highly modified M90 configurations an easy, affordable upgrade path. By selling your airbox, headers, and 42# injectors, you can make back some of the cost. Additionally, cars running a intercooler can keep most of the existing setup. The twin charged kit works well with supercharged cam profiles. A twin charged setup, given similar mods will always outperform a turbo only solution.
I got that from ZZP's website.
Old Jul 2, 2010 | 10:29 PM
  #32
nighthawk626's Avatar
yea i was looking at zzp too but what i wanna know is: cant any turbo kit that goes with an l67 work or does it have to be the type that zzp sells
Old Jul 3, 2010 | 03:15 AM
  #33
From what I read...it looks like this is the only kit that is both supercharger and turbo. There are some kits that are for the L67 but you will lose your blower or they will use the blower housing. I hope this helps.
Old Jul 3, 2010 | 12:02 PM
  #34
so thats the only turbo kit that can work in sync with our supercharger?
Old Jul 3, 2010 | 12:10 PM
  #35
Wilco's Avatar
As far as I know, short of fabricating one, the kit from ZZP (Strattama) is the only kit able to work with the L67/L32 S/C and it requires a bit of tuning to make it work smoothly. Failure to tune it right will cause engine failure. It would be in the owner's best interest to own a tuner like HP Tuner.
Old Jul 4, 2010 | 11:23 AM
  #36
You theoretically could- the ZZP turbo kit doesn't use any specific hard parts to use the SC also- but you'd need to buy their vacuum switching parts, and do your own tuning if you got another kit.
Although, IMO the ZZP and Stattama kits are the best out for the 3800s now anyways.
Old Jul 7, 2010 | 10:11 AM
  #37
Montess2k's Avatar
I agree with everything bumpin' says..
Your looking a lot at various goals....first you said you wanna beat up on Mustangs, for that a bolton/modded Supercharged Monte should be able to handle that goal...if mine came Supercharged I woulda never went turbo...
Second the biggest issue as stated is fwd...I run 9 pounds on my setup, I was told I could go up to 15 without an issue, but even at 9 I can't get traction outta the whole no matter what I do (Granted I don't race at tracks) I am quiet happy at 9 pounds, and yes it does beat up on mustangs....ussually mostly cause they don't expect it, and by the time they realie what's happening I'm already ahead and they can't catch up...
Also as far as Diff's go, I went with a Torsen LSD I heard it was the best, not sure how true that is But I am satisfied with it...
As far as going 9's/10's and being able to use it on the street as a dd to "beat up" on Mustangs....good luck...hope you have a trailer following you around were ever you go!
Please do research after you pay off the car to see how much this will cost, and know you will need a lot of pateince for all the time's the car is down from being broke....
Joe
Tballard182
Sep 20, 2010 06:48 PM
Buknasty
19
Aug 22, 2010 01:21 PM
White06MCSS
Nov 11, 2007 03:16 PM
1stz51
Jun 30, 2007 08:41 AM
