7th Gen ('06-'07): Tune up time !
Old Aug 29, 2014 | 05:30 AM
KillerB's Avatar
Originally Posted by Hiroska
So this will be my first tune up on a car, ever, and I know its basically removing plugs and wires, but is there anything special i should know or anything I have to get? I remember some of my buddies using a socket to pull them out, but I dunno what size if for the monte carlo...Any help would be appreciated. And also.....
Im baaaaaaaaaaaaaaaaacccckkkk ;]
Standard 5/8'' spark plug socket will get the job done. I suggest removing the rear coil pack assembly, when doing the rear set of plugs. Waay easy after that is removed a few connectors and a 10mm socket. No need to remove front motor mount, this ain't no v6..
Old Aug 29, 2014 | 07:57 AM
SSilver's Avatar
Some people make things more complicated then they need to be. No need to remove engine mounts or tilt the engine. Be a Man and get your hands back there and do it. No special tools required. Just common sense and patience...
Old Aug 29, 2014 | 09:47 AM
Hiroska's Avatar
lol Thanks fellas, parts come in wendsday, so ill do it then, Im gonna take my tools to the store today to get the right socket.
Old Aug 29, 2014 | 11:08 AM
Mels SS's Avatar
Make sure you put anti seize on the spark plugs on the install and Dielectric Grease for the wires. Also dont overtighten remember the heads are aluminum.
wkimes
May 19, 2015 02:09 PM
07ss_ls4
13
May 9, 2014 12:17 PM
tps221
Jun 6, 2012 09:06 PM
inssanity21
Mar 9, 2009 10:46 PM
Dave McFly
May 11, 2008 08:28 AM
