Transmission whine
Old Aug 13, 2009 | 11:02 AM
bearbear3_4's Avatar
Default Transmission whine
Has anyone changed their trans fluid and then all of a sudden have a very low whine when you accelerate?
I changed mine yesterday in prep for going to the drag strip this weekend for the first time, and now I have a very low whine when I accelerate. I've checked the fluid level and its right where it needs to be at, I used the correct fluid, Dexron 6 full synthetic, replaced the filter while I was at it. The whine is very very quite but its something that was never there before. Can only hear it with radio off, the fans off, windows rolled up. and seems to go away after shifting into second.
Old Aug 13, 2009 | 12:45 PM
MAMONTE's Avatar
i've had a tranny whine after changing the fluid, but it was because it was a quart low on fluid, so I just topped it off, and the whine went away...
Did you drive thecar around for a while before checking the fluid level again? You did check it with the car turned on right?
How much trans fluid did you put in it after the change. With my 2006, I have to but like 7.75 quarts in it with a pan drop, and filter change...which is a tiny bit more than the manual says it takes (7.4Q)...
Old Aug 13, 2009 | 01:43 PM
Proper checking without driving around.
Start the car, let it warm up to normal operating temp (around 10-15 mins)
sit the car on a level area
shift through all the gears slowly from P down to 1, and then slowly back.
Then get out and check the dipstick.
I agree, the whine isn't right...
Old Aug 13, 2009 | 09:18 PM
06 Monte LT's Avatar
Wow, I think you guys just solved my problem. I have the same whining up to about 30mph and then goes away.
Old Aug 13, 2009 | 09:46 PM
03SS/00GSE/93LX's Avatar
Definitely check the fluid level like these guys suggested. It could just be a slightly louder trans pump due to cleaner/thinner fluid too.
Old Aug 13, 2009 | 11:50 PM
I don't know what it was but now its gone. Did a 40 mile drive, trippled checked the level still full, but it doesn't matter cause now the noise is gone.
Absolutpolack
Oct 13, 2010 08:36 AM
MAMONTE
Mar 4, 2010 09:42 AM
cain45
Aug 20, 2007 08:57 AM
SoCalSS
Aug 18, 2005 12:45 PM
SoCalSS
Aug 13, 2005 04:51 PM
