6th Gen ('00-'05): transmission problems
Old Dec 20, 2023 | 10:55 AM
ramirez1957's Avatar
Unhappy transmission problems
ok i got the axle problem fixed now when i take off the car feels like the breaks are pressed and when i do get the car moving the car goes from 1 st gear to 4 th gear
Old Dec 20, 2023 | 12:07 PM
Has this transmission ever worked properly for you or has there been an issue since you installed it?
What ended up being the problem with the axles?
Old Dec 20, 2023 | 01:43 PM
when I removed the axles I took them apart so I can insert into the other transmission so I didn’t lose the transmission fluid and make a mess and I stuck the transmission in I got the axle ends reversed and that what happened now that I put them in the right way they stayed in okay I still have the no start but the only way I can test the transmission is to just to jump the purple wire from the starter to the hot cable and it would start I would start to move it felt like the brakes were pressed and it would go from 1st to 4th gear and on the dash it would not mark what gear I was in so that is the problem now the car never moved cause I bought it with a bad transmission
Old Dec 20, 2023 | 03:39 PM
To whtmonte's point, I'd be very suspect that this transmission is broken as well. If its never worked in your car and doesn't seem to be working right now, theres a chance it is broken.
I didn't totally catch all of the issues from the other thread (no start problem). IMO I'd focus on getting that fixed first. With all of the electronic controls, I'd be skeptical of saying good or bad with having to jump wires to make things work. It would be ideal to get it starting and running normally first before diving back into the transmission operation.
domo_smash
Mar 31, 2016 07:28 PM
DRuben
16
Apr 10, 2014 07:19 PM
04SuperchargeR
Mar 7, 2013 01:54 PM
WildWestSS
Aug 5, 2011 06:49 PM
GYROBLEU
Jul 19, 2010 10:00 AM
