6th Gen ('00-'05): Transmission issue
Old Oct 16, 2017 | 02:42 AM
vincenti's Avatar
Originally Posted by mc1978
Noted. Where are they located?
the lines going to the radiator are located on the passenger side of it, towards the engine bay. they're metal. one is near the top of the rad, the other closer to the bottom
Old Oct 16, 2017 | 02:44 AM
vincenti's Avatar
Originally Posted by Auroradawnnnn
I'm having some tranny issues, I have a leak in the pan. I know I need it replaced, but it's not a terrible leak so I just keep buying fluid until I can save up enough to have the pan replaced. BUT, my rear passenger rotor and rear brakes were just replaced today and I thought that this was the cause of my transmission slipping, because it doesn't always do it. It's usually after I've driven and stopped at a light or stop sign a few times.. It's like it makes this weird skipping feeling, and the RPM gauge shoots up to 3 and 4 and it just doesn't want to go at all after stopping. But if I shut the car off and turn it back on after a minute or two, it will drive just fine. Other than the obvious, change your pan option, does anyone have any ideas what may be causing this?
is your SES light on?
Old Oct 16, 2017 | 11:29 AM
Auroradawnnnn's Avatar
Yes it actually just came on the other day. It wasn’t on before when this problem was happening.
Old Oct 24, 2017 | 01:31 PM
coolhand's Avatar
If your engine rpm is going crazy, it could be your throttle position sensor, or like in my case I had a similar problem, the plug going to the sensor needed to be replaced also.
Old Aug 26, 2018 | 08:49 AM
simsfan72's Avatar
2005 Monte Carlo - intermittent transmission issue, makes a popping noise like it's trying to find the gear, pretty sure the car sat for a couple years, my mother purchased it in 2015 w/only 75000 miles on it, and when she passed away she gave it to me and it only had 80000 miles on it, had to drive it from Montana to Florida, issue started about half way back, stopped and had the transmission fluid flushed/replaced, issue not as bad but is still occurring (usually only happens as I am taking off from a dead stop), being told I need my PCM tuned, did the researched found it may cost anywhere from $50-$400 to fix, I'm not a total idiot when it comes to mechanics but I think this is a little outside my comfort zone and I have been screwed by mechanics before, I am looking for a transmission shop in Tampa FL that can take a look / fix the issue, thank you for your time :-)
el pachuco
Oct 20, 2024 09:30 AM
mkenney
Oct 31, 2017 08:01 AM
Joe Bloggs
Feb 19, 2013 02:09 PM
shamgodlou
Sep 21, 2010 11:23 AM
bearbear3_4
Aug 13, 2009 11:50 PM
