Transmission issue
My transmission is making a whirring noise when initially leaving the driveway ( not heard any other time except when leaving work after 8 hours). It is also slipping intermittently. It slipped once in drive and once in reverse yesterday. This is the first it's slipped in a couple months. The transmission was replaced 2 years ago and I've had to add fluid to it a few times. Before I start throwing different things at it, what's everyone thoughts? I haven't had it serviced yet. I'm hoping it's just the filter that needs to be changed as well as fresh fluid.
really shouldn't have to add fluid unless you have a leak some where..
I added fluid only because it wasn't registering on the stick at all.
Originally Posted by mc1978
(Post 706750)
Unfortunatley, if you've filled it properly and it's still slipping, I think it's just a matter of time before it needs to be pulled for a refresh. |
It's definitely leaking. Once I put fluid in, the whining stops and the slipping stops. I picked up a transmission filter this afternoon. I'm hoping to get that changed soon.
Did that trans come with a warranty?
3 month warranty from Milzy, but that was 2 years ago.
Put some UV dye in the transmission and figure out where it's leaking, might be one of the lines going into the radiator.
Noted. Where are they located?
I'm having some tranny issues, I have a leak in the pan. I know I need it replaced, but it's not a terrible leak so I just keep buying fluid until I can save up enough to have the pan replaced. BUT, my rear passenger rotor and rear brakes were just replaced today and I thought that this was the cause of my transmission slipping, because it doesn't always do it. It's usually after I've driven and stopped at a light or stop sign a few times.. It's like it makes this weird skipping feeling, and the RPM gauge shoots up to 3 and 4 and it just doesn't want to go at all after stopping. But if I shut the car off and turn it back on after a minute or two, it will drive just fine. Other than the obvious, change your pan option, does anyone have any ideas what may be causing this?
